Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 16-01-2013, 23:55
bulky234 bulky234 is offline
Darius DeSpain
FRC #3008 (Falcons)
bulky234 is an unknown quantity at this point
Code deploying problem
So i've been trying to deploy my code to a practice robot and the cRIO is all imaged fine and everything. I try to run/deploy code to it and it says "Connection failed. The network address might be invalid or the target is not responding". We've checked and double check our IP but I could still be doing something wrong. I didn't see anyone else with this problem
Unread 17-01-2013, 00:11
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Re: Code deploying problem
When you created the project, did you enter the correct address for your cRIO?
Unread 17-01-2013, 06:25
Can you successfully run RobotMain using the Run button?
Greg McKaskle
Unread 17-01-2013, 16:10
Bruno#1382's Avatar
Bruno#1382 Bruno#1382 is offline
FRC #1382
Bruno#1382 is an unknown quantity at this point
try to reboot the cRIO via driver station
Unread 17-01-2013, 16:38
Darius DeSpain
FRC #3008 (Falcons)
i've fixed it, it was the wrong address, i entered 10.30.08.2 before but i changed it to 10.30.8.2 and it worked so that one zero was messing it up
