Go to Post Design is iterative, right? - JesseK [more]
Unread 17-01-2013, 00:01
Re: CIM->Victor 884->Arduino not working
The ground pin on a Victor is at the other end of the PWM input connector from the signal pin. The center pin is not used, but it's typically labeled as the power input. Your picture shows the ground and power connections reversed.
