Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 15-01-2013, 16:13
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Linear Actuator for Lifting
Hello Everyone!
My team considers using Linear Actuators to climb the pyramid. Are we allowed to use Linear Actuators if it does not violate the electrical and pneumatic rules?
Thanks!
Begüm
Unread 15-01-2013, 21:16
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Linear Actuator for Lifting
Pre-made electrical linear actuators likely include non-legal motors. They would have to be modified to operate with one or more of the legal motors listed in R32.
If you are using a lead screw, acme screw, or ball screw, without a motor, It should be legal provided you drive it with a legal motor and no other rules are violated.
NOTE: This is my interpretation of the rules and is not official. The only way to get an official answer is via the Q&A system.
Unread 16-01-2013, 16:43
captianjroot captianjroot is offline
FRC #4500
captianjroot is an unknown quantity at this point
My team is considering using a linear actuator to raise/lower a turret. Are there any other limitations regarding size of the actuator?
Unread 16-01-2013, 17:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The only limits are : #1 must use a legal motor, #2 must fit into starting configuration #3 cost.
Unread 16-01-2013, 17:24
Begum,
If you would like to PM me with the part number I can give you my opinion off line. Otherwise, you might want to pose the question to the Q&A for an official response.
Unread 17-01-2013, 00:30
Tangert's Avatar
Tangert Tangert is offline
FRC #4467 (Titanium Titans)
Tangert is an unknown quantity at this point
Depending on the weight of your bot pneumatic linear slide actuator will probably not lift it. We tried it today with a 110 Lb weight and 250 MM and 300MM actuators neither would handle a vertical lift. The other thing to realize is that linear actuators always stay the same length. which may make it difficult to use for climbing.
Unread 17-01-2013, 00:41
MentorPrice's Avatar
MentorPrice MentorPrice is offline
Mentor/FIRST Alumni/Engineer
AKA: Kevin Price
FRC #1708 (Amp'D Robotics)
MentorPrice is an unknown quantity at this point
They are not allowed in the competition because of illegal parts and the pre-made nature of it.
Team #1708 Drive Team & Member (2006-2008)
Team #4547 Westmont Hilltoppers Mentor (2013-2014)
Team #1708 McKeesport Amp'D Robotics Mentor (2009-2012, Current)
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.”
Nikola Tesla
“A Machine to End War” (Liberty, February, 1935)
Unread 17-01-2013, 07:47
Explain please.
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
A linear actuator is a commercial off the shelf (COTS) item, so it should be okay, as long as you use an approved motor on it (Table 4-1), and the "fair market value" does not exceed $400 (Rule 4.1.3).
Unread 17-01-2013, 07:54
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Since this is in the pneumatics section, we are talking about pneumatic linear actuators. Thus, no motor is involved.
Jim
Unread 17-01-2013, 08:33
AKA: Kevin Thorp
Rule R78 in Section 4 states you can use a pneumatic cylinder. A linear actuator is just a guided pneumatic cylinder, so I think you're okay.
However it might be difficult to find one with enough force for under $400. Remember, we can only use 60 psi, so if you needed 150 lbs force (robot, battery, bumpers & a safety margin) you'd the need piston area to be 2.5 square inches (150/60). That's 1.78" diameter or bore. The next common size is a 2" bore, but those are very expensive, WAY over the $400 limit.
Here are a few listed on Mcmaster Carr.
Unread 17-01-2013, 08:43
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
You can get free cylinders, up to 2"x36" in the KOP via the Bimba PDV.
Unread 17-01-2013, 08:54
AKA: Kevin Thorp
Yup, and you can use a Bimba cylinder to build your own linear actuator. It probably won't be as precise as a COTS linear actuator, but you don't need precise to climb pipes.
Unread 17-01-2013, 09:09
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
If you're going to use pneumatics building your own linear actuators are a must to stay within cost. Getting normal cylinders (http://www.mcmaster.com/#standard-air-cylinders/=l2ot0l, using the PDV for Bimba works well too) and using linear slides from somewhere like Igus, 80/20, or Bosch as guides and support works well.
If you only need high force in one direction clever use of springs, surgical tubing, etc. can allow you to cut down the cylinder size. A 1.5" bore cylinder has about 105 lbs of force, loading it with 30 lbs of force from surgical tubing in one direction can give you 75 lbs extending but 135 lbs retracting.
Unread 17-01-2013, 09:18
pfreivald's Avatar
pfreivald pfreivald is online now
AKA: Patrick Freivald
You might also want to do the math on how much of an air charge will be needed to lift the robot using pneumatics (with whatever mechanical assist you've got built in).
For a thirty-point climb, we found it rather prohibitive. For a ten-point hang it might be just what the doctor ordered!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
