Go to Post This thread is just as lethal as any design your own game thread. - Schnabel [more]
Unread 17-01-2013, 06:51
salandri_s's Avatar
salandri_s salandri_s is offline
FRC #4145
salandri_s is an unknown quantity at this point
Scheduler.getInstance().run() throws a null pointer
Scheduler.getInstance().run() throws a null pointer exception. Anybody encountered same problem and found a fix? If yes, please share.
Unread 17-01-2013, 07:18
Re: Scheduler.getInstance().run() throws a null pointer
It's unclear if the Scheduler call is throwing a null pointer, or if one of your commands is. Can you post the full stack trace?
Unread 17-01-2013, 11:10
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
It's sure to be an exception being thrown in .run() since it is a singleton instance. Something in your scheduled commands is throwing the error.
All opinions are my own.
Unread 17-01-2013, 12:52
salandri_s's Avatar
FRC #4145
Thanks for responding.
Here is the exception stack trace.
[frcrun] [cRIO] 1969/12/31_16:04:53.119,E,WkwFrcRobot2013,teleopPeriodic() ,java.lang.NullPointerException, message=Cannot put a null value into networktables.
[frcrun] [cRIO] java.lang.NullPointerException: Cannot put a null value into networktables
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.NetworkTableN ode.putValue(NetworkTableNode.java:95)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables.NetworkTable.p utValue(NetworkTable.java:406)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.command.Scheduler.run(Schedu ler.java:208)
[frcrun] [cRIO] at us.oh.k12.wkw.robot.WkwFrcRobot2013.teleopPeriodic (WkwFrcRobot2013.java:331)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.otBase.startApp(RobotBase.java: 169)
[frcrun] [cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[frcrun] [cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[frcrun] [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[frcrun] [cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[frcrun] [cRIO] at com.sun.squawk.Isolate.run(1506)
[frcrun] [cRIO] at java.lang.Thread.run(231)
[frcrun] [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[frcrun] [cRIO] ijava:165)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:169)
[frcrun] [cRIO] at cn static method #3 of com.sun.squawk.VM(bci=6)
Unread 17-01-2013, 12:58
AKA: Joel Gallant
It appears that it has nothing to do with Scheduler.run(). Are you using NetworkTables to send and receive data in any way (or SmartDashboard)? It seems you've sent a null reference through NetworkTables.
Unread 17-01-2013, 17:10
detruby detruby is offline
Dave Truby
AKA: Dave Truby
FRC #4145 (Wolf Pack)
detruby is an unknown quantity at this point
In wpilibjava jar, in Scheduler.java line 208,
m_table.putValue(string.valueOf(++count), e.getData().getTable());
Would return the error about putting a null in the network table. Looks like a code bug to me.
Unread 20-01-2013, 15:31
AKA: Brad
#0190 ( Gompei and the Herd)
Can you post a (preferably) small program that causes the NULL pointer exception that you are seeing?
Thanks,
Brad
Brad Miller
Robotics Resource Center
Unread 21-01-2013, 13:38
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We had this issue because we removed the line in RobotTemplate that initialized the example autonomous command, but we did not get rid of the line that started it.
Unread 22-01-2013, 08:17
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
is there some code in the teleopInit()?
Unread 07-02-2013, 10:19
carneeki carneeki is offline
AKA: Adam
FRC #3132 (Thunder Down Under), FRC#4774 (LAN Down Under)
carneeki is an unknown quantity at this point
Hi salandri_s,
Did you wind up fixing this? If so, could you please post your troubleshooting method? Our team (#4774) is having some trouble finding where the null pointer is creeping in as it doesn't appear in our stack trace either.
Thanks,
Brad
Hi Brad,
Did anybody post any example code to you? If not, I can share our code with you. I'm heading into the workshop in about 7 hours. I will try and strip out everything to see if I can get rid of the exception. If I have no luck, I'll create a Gist and share the link.
FRC-3132 - Thunder Down Under - Mentor since 2011
FRC-4774 - LAN Down Under - Mentor since 2013
VK2JSI... Adam
Unread 07-02-2013, 15:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Originally Posted by carneeki View Post
Hi salandri_s,
Hi Brad,
The person above you was correct, you started a command that was not initialized. This throws a NetworkTable error because the commands use NetworkTable to put buttons on the driverstation/dashboard
Unread 07-02-2013, 16:37
AKA: Brad
We found a bug in the C++ and Java libraries where doing a putData() of the Scheduler instance will cause the program to crash. That has been fixed and will be released later today or tomorrow morning.
So if you have code like this:
SmartDashboard.putData(Scheduler.getInstance())
it will be fixed in that update.
Sorry about the annoyance.
Brad
Brad Miller
Unread 07-02-2013, 16:57
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Brad
Didn't know you could do that
Unread 07-02-2013, 18:58
AKA: Brad
You can do that,
and the update just got pushed out. Look for it in Netbeans.
Brad
Brad Miller
Unread 07-02-2013, 19:04
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
You can do that,
Brad
How? "Check For Updates" is empty
