Go to Post BTW - using any Lavery clue to figure anything out could be equally impossible. - Raul [more]
Unread 17-01-2013, 08:49
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Very Basic Java Code Needed
So it is our first year with Java and we have set up our IDE we have a connection to the cRio and can ping. We started a simple robot template, and created 4 motors, and then we set the motors to a power of 1 (100%) in the autonomous for 5 seconds. However when we deploy the code and click enable on the drive station, nothing happens. So does anyone out there have a very simple code that turns on motors that we could try?
(Sorry to bother you all, but we really don't have any mentors for this sort of thing)
Unread 17-01-2013, 10:30
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Re: Very Basic Java Code Needed
There are several things that could be wrong. Is the driver station set to autonomous? Is the robot status light indicating any issues? Either post your code here or PM it to me and I'd be happy to help.
I'm a mentor looking for a home in Southern California! I know Java, C++, electrical and mechanical.
Need Java or C++ help? Send me a PM!
Unread 17-01-2013, 11:06
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
You should also be sure to check you have put the correct ports down. Ports are which header the pwm cables are attached to on the digital sidecar. Also, how did you turn them on for 5 seconds? The Timer class in wpilibj should be what you're using (probably not Timer.delay() though). Posting your code would be helpful.
All opinions are my own.
Unread 21-01-2013, 20:22
FRC #6054 (Dukes)
Ok, so it turns out to be a loose ribbon cable to the sidecar. The code worked fine. We had a momentary brain issue.
Unread 21-01-2013, 22:07
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Those are fun aren't they? We have them all the time.
I code stuff.
