Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
  #31   Spotlight this post!
Unread 17-01-2013, 12:31
pfreivald's Avatar
AKA: Patrick Freivald
Re: *Warning* On talons!!!!
Originally Posted by Mike Copioli View Post
Bottom line:
You will not draw 133 amps with your CIM motor in FRC, not even close. BTW the spec sheet on the Talon reads 60 Amps continuous and 100 peak. The FET's in side the Talon are rated at 100 amps continuous. We de-rate from the 100 amps to be conservative. The reason is because of the heat that is generated at continuous currents higher than 60 amps.
Hooray, math!
Thanks for taking the time to outline the design and the rating decision, Mike.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
