Go to Post I believe in the rookie teams. - Arefin Bari [more]
Unread 17-01-2013, 12:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Attaching a shaft to a Vex Motor
It seems the vex motor outputs are simply a square shaft receiver. I don't see any way to lock the shaft in the motor. We were interested in direct driving a wheel from a vex motor, and having a short 'arm' on another one (5 inches).
Am I correct when I say that we have to create our own shaft retaining method with a shaft collar and mounting plate?
Unread 17-01-2013, 13:09
AdamHeard's Avatar
Lead Mentor
Re: Attaching a shaft to a Vex Motor
We did a mounting plate and bearing support last year, with the motor mount points already long this doesn't take much more additional thickness. We used. 125 Plate.
I suppose you could glue the shaft in, but then you'd lose the 2nd bearing support.
Unread 17-01-2013, 13:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
That's how many VEX teams do it.
Hi!
