Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 17-01-2013, 14:48
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
DS IP Address
We set the IP address of the DS network adapter to some IP that we think appropriate in Windows (10.xx.xx.5 for instance). When we run the DS software, it appears to change the IP address on the adapter to 10.xx.xx.9. Can someone confirm if this is the expected behavior and if it is, why?
I'd swear this was not happening with the 2012 spec DS software but I can't be 100% sure...
Unread 17-01-2013, 14:57
Re: DS IP Address
When the Driver Station is started there are options to set the network adaptors automatically.
The automatic settings are:
  • 10.xx.yy.5 Local Area Connection
  • 10.xx.yy.9 Wireless Connection
You can change this behavior on the Setup tab -> Choose NIC...
You might have had your 2012 DS set to manual.
Unread 21-01-2013, 22:46
dowster dowster is offline
Breathes Code
AKA: Brady
FRC #1091 (Oriole Assault)
dowster is an unknown quantity at this point
Re: DS IP Address
Are we able to use any ip address that conforms to 10.te.am.* standard?
Unread 22-01-2013, 07:35
Re: DS IP Address
The Driver Station will be 10.te.am.5 on the competition field, and it's easiest to stick with the FRC IP conventions. Using conventions make it easier on all of us. On the field other IPs may be blocked.
  • 10.te.am.1 = Robot DLink
  • 10.te.am.2 = cRIO
  • 10.te.am.4 = extra team router (optional)
  • 10.te.am.5 = Driver Station/programming laptop (Ethernet)
  • 10.te.am.6 = Programming laptop
  • 10.te.am.9 = Driver Station/programming laptop (wireless)
  • 10.te.am.11 = Camera
Technically, off the field and out of the competition pits only the cRIO IP is fixed and unchangable (or at least is very hard to change).
Everything else is negotiable and your programming and other laptop(s) can be any 10.te.am.xx as long as it doesn't conflict with any of the pre-assigned IPs. The only hard and fast IP is the one assigned to the cRIO.
The most common additions are the use of DHCP at home for dynamically assigning addresses above 10.te.am.20 or so.
The use of additional cameras at 10.te.am.12+
The use of additional programming laptops at 10.te.am.xx
