Go to Post What good will it do to have 10,000 teams who barely have a clue and are just scraping by versus 2,000 teams that are actually sustainable? - Cory [more]
Unread 17-01-2013, 14:51
jamierose jamierose is offline
FRC #4039 (MakeShift)
jamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nice
Feeder Station Angle
While designing a mechanism to intake discs from the feeder station, I realized that I did not know the angle of the feeder station relative to the alliance station, and I was unable to find an angle in the rules or field drawings.
Is there a place I could find the angle?
Thank you very much.
Unread 17-01-2013, 14:56
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Feeder Station Angle
All of the FEEDER STATIONS consist of a 44 in. wide shield of clear polycarbonate. In the center of the shield are three horizontal FEEDER SLOTS, 12 in. wide by 3 in. high. These slots are located 22 in., 42 in. and 62 in. from the FIELD carpet to the bottom of the slot. Each slot has a slide attached to it on the FEEDER side of the plastic. These slides are 8 in. long and are at a 30-degree incline.
Emphasis mine. It's in the game manual (section 2.2.7), rather than the drawings
Unread 17-01-2013, 15:01
Thank you for the help, but that is not actually what I was looking for.
I was trying to find the angle of the entire feeder station wall.
This picture is an aerial view of the field CAD my team has. The black arrows in the bottom right point to the angle I am looking for.
Unread 17-01-2013, 15:14
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Just measure the angle in the CAD drawing.
Unread 17-01-2013, 15:20
This CAD drawing was done without proper measurement on some parts. It's mostly just to visualize the field and measure some linear distances.
Unread 17-01-2013, 15:21
I don't have quick access to the field dimensions or I'd give you the answer. But I can tell you how to find it.
You know the width of each of the three driver stations. You know the width of the field. Subtraction (and division by two) gives you the amount of field width taken up by the feeder stations in the corner, which is one side of a right triangle. You know the width of each of the two feeder stations, giving you the length of the hypotenuse. Trigonometry tells you the angle.
Unread 17-01-2013, 15:31
Thank you for the answer. I talked to a mentor about this, but we decided to ask on Chief Delphi in the interest of saving time. It seems that I'll just end up calculating it.
Once again, thank you very much!
Unread 17-01-2013, 16:27
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
For those still wondering, the angle of the feeding slot wall in relation to the alliance wall is 52.14709727 degrees
The attached image shows the basic way to figure this out in CAD software.
Name:	feeding slot wall angle.png
The four corner walls were contrained equal to each other, the two alliance walls constrained equal to each other, and finally the two side walls constrained to be equal to each other.
-Nick
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 17-01-2013, 16:36
Attachment 13548
-Nick
Thank you very much for calculating this!
