Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 17-01-2013, 15:29
Re: CIM->Victor 884->Arduino not working
500 ma seems way too high. You might even have damaged the opto-isolator's emitter.
I've never been able to find a Victor schematic, but the datasheet for the Jag's opto-isolator says it has an absolute maximum continuous current rating of 60 ma for the input.
The cable I am using for my test equipment here delivers about 5.6 ma to the Victor during the pulse, and it works fine.
Can you post a picture of your scope's current waveform?
Unread 17-01-2013, 15:44
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
I won't be able to get back into the school till later tonight or tomorrow, but I'll get that to you as soon as i can. Next time i'll try putting a larger resistor in line to lower the current down to 50mA and see if that changes anything. I just hope i haven't damaged the victor.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 17-01-2013, 16:24
50 ma is still way too high.
In the Jag's opto-isolator, there's a 150 ohm series resistor. In the DSC, there's a 330 ohm series resistor in the PWM signal output. Total 480 ohms. Do the math. 11 ma should be enough.
I just measured a Vic I have here. With 1.5 VDC applied to the input, the current is 0.00562 amps. Subtract 0.7 volts for the LED (I think?) and use R=V/I = (1.5-0.7)/0.00562 = 142 ohms series resistor. So it seems to be similar to the Jag.
Unread 17-01-2013, 16:36
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
FYI, that Altoids Can ran the old victors, and currently running Jags without issue. I have not tried with Talon, or the new Victor.
The sooner we get behind schedule, the more time we have to catch up.
Unread 17-01-2013, 15:47
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
That's what I got on the o scope. I put a 10 ohm resistor in line with the signal wire and took the voltage above and below the resistor then hooked the other channel on the o scope to a constant 0.1v and used the math function to multiply the channels
Forgive me for asking the obvious question but are both probes set to the same gain (x10, x1)?
