Go to Post I believe there is a strong link between a reliable drivetrain and an inspirational FIRST season. - Joe Johnson [more]
Unread 17-01-2013, 15:44
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: CIM->Victor 884->Arduino not working
500 ma seems way too high. You might even have damaged the opto-isolator's emitter.
I've never been able to find a Victor schematic, but the datasheet for the Jag's opto-isolator says it has an absolute maximum continuous current rating of 60 ma for the input.
The cable I am using for my test equipment here delivers about 5.6 ma to the Victor during the pulse, and it works fine.
Can you post a picture of your scope's current waveform?
I won't be able to get back into the school till later tonight or tomorrow, but I'll get that to you as soon as i can. Next time i'll try putting a larger resistor in line to lower the current down to 50mA and see if that changes anything. I just hope i haven't damaged the victor.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
