Go to Post I am a FRC Coach/Mentor I don't know the meaning of the words "days off" or "rest". At least not from January to May. - Bob Steele [more]
Unread 17-01-2013, 15:47
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: CIM->Victor 884->Arduino not working
That's what I got on the o scope. I put a 10 ohm resistor in line with the signal wire and took the voltage above and below the resistor then hooked the other channel on the o scope to a constant 0.1v and used the math function to multiply the channels
Forgive me for asking the obvious question but are both probes set to the same gain (x10, x1)?
Unread 17-01-2013, 15:59
ericomoura ericomoura is offline
FRC #0383 (Brazilian Machine)
ericomoura is an unknown quantity at this point
Here, this might help you.
http://imageshack.us/photo/my-images/185/victormc4.png/
Unread 17-01-2013, 16:04
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Originally Posted by jamie_1930 View Post
Could you show me how you set up this up electrically? In the victor manual it says to use a pwm signal driver if you are not using an ifi controller and I can't really find one on the internet. So I assumed I could boost up the amount of current by using a mosfet. I got that working and then I measured the current over time with an oscilliscope and it's pretty noisy. The voltage is a perfect square wave, but the current starts of at 0A and curves up to around 500mA and does a 10-20mA bounce as it goes up.
I will have to check, but I do not remember doing anything with the circuit. From 50 year old memory, I think I have the white PWM wire going to the arduino output, red to the +5v and black to 0V, and it worked. It isn't pretty but has worked for a couple of years.
I powered it with a Usb cable, we have a utility tote that has an old battery, power cut off, and a plate with 4 auto cigarette lighter sockets for powering cell phone charges at events, and a built in usb charger.
The sooner we get behind schedule, the more time we have to catch up.
Unread 17-01-2013, 16:24
Next time i'll try putting a larger resistor in line to lower the current down to 50mA
50 ma is still way too high.
In the Jag's opto-isolator, there's a 150 ohm series resistor. In the DSC, there's a 330 ohm series resistor in the PWM signal output. Total 480 ohms. Do the math. 11 ma should be enough.
I just measured a Vic I have here. With 1.5 VDC applied to the input, the current is 0.00562 amps. Subtract 0.7 volts for the LED (I think?) and use R=V/I = (1.5-0.7)/0.00562 = 142 ohms series resistor. So it seems to be similar to the Jag.
Unread 17-01-2013, 16:36
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
FYI, that Altoids Can ran the old victors, and currently running Jags without issue. I have not tried with Talon, or the new Victor.
Unread 17-01-2013, 16:58
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Originally Posted by Whippet View Post
Have you tried connecting the grounds between the FRC battery and the Arduino?
This is not necessary because of the optocoupler that Ether has mentioned.
Your PWM source just has to be able to turn on the LED in the optocoupler.
For the Jaguar, the Turn On Threshold Current for the optocoupler (H1L1M - Datasheet) is 1.6 mA. I don't know the exact optocoupler used in the Victor, but it should be very similar.
Even though I have never played with an Arduino, I would think that its outputs should be able to source >1.6mA at 5V.
I agree that the optocoupler could very well be damaged (pending validation on the 500mA measurement) and possibly the Arduino pin as well if the first attempt was made without a series resistor.
-David
Unread 18-01-2013, 07:56
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
I checked last night, and I do not have have any circuitry between the arduino and the white of the pwm, except for a solder joint to switch it to solid wire to plug into the arduino socket.
I just plugged it in and it worked.
Unread 18-01-2013, 13:39
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Ok so here's the update I tryed putting a resistor in line with the signal wire to lower the current, but it still didn't work. So I opened up the victor (which just as an fyi on the pcb says Victor 883 rev F so it's still mainly the same as the victor 883) and found that it had a CNY17F optocoupler inside and based on the data sheet I was pretty sure that I blew it. I then hooked in some alligator clips to test and again I was pretty sure that it was busted. Now we've soldered out the CNY17F and are going to replace it with a PS2501 optocoupler. The pins don't match up exactly so we've snapped of two pins of a 4DIP IC socket and am soldering into where the CNY17F was and we're going to stick the PS2501 into another 4DIP IC Socket and join the two socket by the appropriate pins.
When this is all finished the victor should (fingers crossed) function.
cny17f
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 18-01-2013, 17:31
AKA: Mr Tanguay
This is how everything was hooked up originally and I've also tried hooking up a mosfet powered by the 5v line of the arduino. And I've also tried putting a 5v regulator powered by the FRC battery and then using the 5v line to power a mosfet to boost the signal to the victor, but everytime the victor just flashes orange (no pwm)
After taking another look at the wiring diagram that was originally posted I think I see a problem concerning the PWM cable wiring. If the diagram is correct, the ground wire from the Arduino board is connected to the +5 V in of the Victor. In PWM, the ground and signal are on the outside wires and the +5V wire is on the inside.
Don't know if this observation is helpful.
**** Please disregard. Mr. Anderson already pointed this out ******
Unread 18-01-2013, 17:35
The center +5 wire is required when using a PWM cable to control a servo (that's how the servo gets its power)
BUT
Only the GND and Signal (outside pins) are required for the PWM input to the motor controllers. The center pin goes nowhere and does nothing.
Unread 18-01-2013, 17:47
AKA: Mr Tanguay
BUT
Ether,
I didn't know that. Thanks.
Unread 18-01-2013, 17:51
Ether,
Excerpt from the Jag schematic attached. Notice the center pin.
Name:	Jag PWM input.png
