Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 17-01-2013, 17:04
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
Frc DashBoard
i have no really experience with Ni Labview but would like to build a dash board any suggestions on were to start?
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 17-01-2013, 18:29
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: Frc DashBoard
The following link should have what you're looking for (Thanks to Greg McKaskle for the correction):
https://decibel.ni.com/content/docs/DOC-26296
A real plethora of resources on this site. Should have everything you need.
Unread 17-01-2013, 21:12
Re: Frc DashBoard
https://decibel.ni.com/content/docs/DOC-8923
contains many of the newer tutorials.
Greg Mckaskle
Unread 17-01-2013, 21:44
Re: Frc DashBoard
Originally Posted by propionate View Post
If you want to customize the dashboard, this tutorial goes through a number of important items in that process:
http://www.lvmastery.com/TipJar2009-02-10
The video is from 2009 - if anyone has a more recent instructional item please share.
The dashboard went through a major rewrite this year. Unfortunately, that makes that tutorial obsolete.
Unread 17-01-2013, 23:05
propionate's Avatar
AKA: Stephen
Re: Frc DashBoard
Thanks to both of you for the update. I'll change the link to avoid any confusion.
Unread 19-01-2013, 20:23
splatter's Avatar
AKA: Robert
Team Role: CAD
Re: Frc DashBoard
i feel like there is something i am missing i have not been able to find any parts in the pdf which talk about writing the robot code in C++ and then taking the C++ calls and making them available in labview that way i can interface them with gauges for the dash board
FIRST Team 271
<Electrical, CAD>
Unread 19-01-2013, 22:12
Re: Frc DashBoard
If you use the C++ version of the dashboard on the robot, you can connect to it from the LabVIEW dashboard simply by naming the variables the same. To connect a LabVIEW gauge to a variable, you simply place it in the tab control on the dashboard and give the control the same name as the variable.
Greg McKaskle
Unread 20-01-2013, 13:25
splatter's Avatar
AKA: Robert
Team Role: CAD
Re: Frc DashBoard
thanks for your help i will try what you said today and i am also having trouble centering the dashboard in the run window.
Thanks in advance
FIRST Team 271
<Electrical, CAD>
