Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 17-01-2013, 19:14
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: 90 ON PYRAMID
GTA West would be a good place with 1114 and 2056 and ?????
Would sure be fun to see.
Unread 17-01-2013, 19:19
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Unfortunately that is never going to happen. I'd never put anything beyond 1114 and 2056. But the field in Canada isn't even close to deep enough for them to pick up a 30 point climber as the final draft pick.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 17-01-2013, 20:30
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: 90 ON PYRAMID
Based on this logic (and it seems sound enough to me) a 30 point climber is virtually guaranteed to be picked by someone.
Alan Gilgenbach
C.O.R.E 2062
Unread 17-01-2013, 20:47
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: 90 ON PYRAMID
No, never, not at CMP, not at IRI.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 17-01-2013, 21:18
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: 90 ON PYRAMID
Counter-intuitive Prediction: It will not happen in an elimination match, but will in a qualification match, multiple times. Most likely a certain California regional, both district championships, as well as Championship divisions (not on Einstein) and IRI as long as climbing points stay the same or increase at those two events.
Any robot that can climb to the third level will be picked before any one elimination alliance can get three. It is more likely that three will be paired randomly.
Also, more teams than expected will climb from the inside of the pyramid, so not all can fit.
Unread 17-01-2013, 21:33
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
Re: 90 ON PYRAMID
I think we may see three robots on a pyramid, but i doubt they will all be in the 30pt zone. The chances of three 30pt robots pairing together is slim already. Add the fact that space at the top is limited and teams may be afraid of shaking each other off, and it seems like a big gamble for teams to make unless absolutely necessary. My bet is that at least two fields will have alliances capable, but they may never attempt it.
Unread 17-01-2013, 21:56
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: 90 ON PYRAMID
Originally Posted by rcmolloy View Post
Silicon Valley/San Jose would have a high probability of having a 90 point hang.
Came to say that SVR probably has a very high chance of producing a triple thirty; they've got some of the best home teams anywhere (973, 971, 254) and they're getting some serious power from out of state as well (233, 118, 148).
Unread 17-01-2013, 22:11
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 90 ON PYRAMID
Maybe this is a bold prediction but I think you will never see it
Not only will many first seeds be unable to climb to the third level and anyone able to climb to the third level will be picked well before 24th in the draft. It isn't like acting as the third in a balance like last year with 4334, these points are self contained and not based on the actions of any other robots so anyone able to 3rd level climb will seed reasonably high and be a key asset to many alliances.
Honestly the only chance I see of it happening is something like the 8th alliance being a full time hanger and them picking two others at the 16th and 17th draft spots -- which is still a bit of a stretch but possible in the deeper events like IRI or a CMP division.
Now if 90 points is enough to win a regional by its self is debatable.
To anyone saying SVR is the place to see it remember that regional is top loaded. There are lots of great teams there but the key to producing a triple climb is a deep midfield the kind of which is seen in Michigan and at Championships.
Unread 17-01-2013, 22:18
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: 90 ON PYRAMID
Exactly what I was thinking. 30 pt climbers will be in high demand at eliminations, and Im almost positive no regional will have 30 point climbers in the 3rd round.
Therefore, the only place it could happen is in a qualifier. Low odds are better that zero.
With the high volume of really good robots that go to MAR every year as a result of the district model, Im almost certain it'll happen there. Probably at Michigan too (Though Im not that familiar with it.)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 17-01-2013, 22:19
Darth Drew's Avatar
Darth Drew Darth Drew is offline
AKA: Andrew
FRC #1701 (Robo Cubs)
Team Role: Student
Darth Drew is an unknown quantity at this point
Re: 90 ON PYRAMID
Any robot that can climb to the third level will be picked before any one elimination alliance can get three. It is more likely that three will be paired randomly...
I think this is a genius prediction, and I wouldn't be surprised if that happened at States in Michigan (or even possibly at the Kettering Regional).
Join me and together we will rule the galaxy
Unread 17-01-2013, 23:39
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: 90 ON PYRAMID
After reading the posts and thinking about it for a little, for it to be done in eliminations it would be very very unlikely, because a 30pt hanger will get picked in the first round. But the only case in which it might happen is in a lucky qualification match at Champs or other high caliber events, with three 30pt hanging teams on the same alliance.
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
Unread 18-01-2013, 03:36
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: 90 ON PYRAMID
Keep in mind, just because teams are considered cali "powerhouses" doesn't mean they'll go for 30. I suspect that there will be no more than five teams that can go for 30 with any kind of consistency at SVR, even concidering how super stacked the event is.
If I was Car Nack, I would bet against it in regional play. Almost all regionals simply will not have 3 robots capable of climbing the pyramid all the way up.
-Plutarch
Unread 18-01-2013, 08:06
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
Re: 90 ON PYRAMID
I think you'll see it, and you don't even need all 3 robots in the 30pt zone to get 90pts ON the pyramid. Technically you just need 6 colored frisbees up there with 2 robots. So getting 90 on a pyramid, absolutely possible. 120 on a pyramid, that's another question
2001 - 2003 - Driver/Student - Team 67
2004 - Drive Coach / Mentor - Team 406
2005 - Mentor - Team 1504
2006 - 2007 - Drive Coach - Team 1256
2008 - 2009 - Mentor - Team 1165
2010 - Present - Mentor/Scouting - Team 3098
Unread 18-01-2013, 09:32
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: 90 ON PYRAMID
I'm fairly certain at least 1 MSC playoff alliance will be selected with the primary strategy of triple 30pt hanging. I wouldn't put it past one of the Alliance 5-8 to employ this strategy.
64/209 --> 24 playoff teams; Michigan is way too deep for it not to happen.
Unread 18-01-2013, 11:00
Chris is me's Avatar
AKA: Pinecone
Re: 90 ON PYRAMID
At regionals, I think everyone is right that it won't happen, but at Championships, especially with the new qualification rules and the chance for finalist teams to go, it's more than likely that a second round pick will be a 30 point hanger, possibly a hanger that can score in the pyramid goal. If you think that is too much to ask for a second pick at the Championship - look at teams like 16 in 2012, 973 in 2011, 3138 in 2010, 971 in 2009... Amazing teams fall through the cracks at the Championship.
That said, the real variable isn't "will a 30 point hanger still be around", but "will the top seeds be 30 point hangers"?
