Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Unread 17-01-2013, 20:14
Rainfur Rainfur is offline
Programmer
AKA: Erik Melton
FRC #3189 (Circuit Breakers)
Rainfur is an unknown quantity at this point
Using JavaCV to detect Rectangles
I'm currently using JavaCV to detect rectangles. However, I cannot get CvArr to work, and because of this, I cannot get cvConvexHull to work.
Is there any source for something like this? Could I get some assistance?
Unread 18-01-2013, 00:39
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Using JavaCV to detect Rectangles
OpenCV refers to CvArr as "metatype", "used only as a function parameter". JavaCV implements this by making CvArr the superclass of the types it stands in for, like IplImage and CvSeq. It's not really supposed to be used on its own. What issues are you having exactly?
http://opencv.willowgarage.com/documentation/index.html is a must-have site for OpenCV programming if you're looking for reference material.
I code stuff.
Unread 18-01-2013, 00:49
Programmer
AKA: Erik Melton
I'm specifically having problems with detecting corners and drawing lines between them.
I have it threshholded right now, however any and all methods I try to use to detect the corners have yet to work.
Unread 18-01-2013, 19:00
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
What methods are you using? What are they doing instead of working? I don't think I can help you properly without more information.
I code stuff.
Unread 22-01-2013, 15:58
divixsoft's Avatar
divixsoft divixsoft is offline
FRC #0835
divixsoft is an unknown quantity at this point
I have that problem as well, when I try this code, it compiles but when I use it I get errors.
    public static WPIContour[] findConvexContours(WPIBinaryImage image)
        image.validateDisposed();
        IplImage tempImage = IplImage.create(image.image.cvSize(), image.image.depth(), 1);
        opencv_core.cvCopy(image.image, tempImage);
        CvSeq contours = new CvSeq();
        opencv_imgproc.cvFindContours(tempImage, storage, contours, 256, opencv_imgproc.CV_RETR_LIST, opencv_imgproc.CV_CHAIN_APPROX_TC89_KCOS);
        ArrayList<WPIContour> results = new ArrayList();
        while (!WPIDisposable.isNull(contours)) {
            CvSeq convexContour = opencv_imgproc.cvConvexHull2(contours, storage, opencv_imgproc.CV_CLOCKWISE, 1);
            WPIContour contour = new WPIContour(opencv_core.cvCloneSeq(convexContour, storage));
            results.add(contour);
            contours = contours.h_next();
        tempImage.release();
        WPIContour[] array = new WPIContour[results.size()];
        return results.toArray(array);
