Also, our robot should be able to pick up frisbees quite well, using both belts and pneumatics |
Re: Picking up frisbees
I could be wrong, but that seems reasonable. |
![]() Our current plan is to allow for the simple (err, "simple") addition of floor loading during Unbag for second districts, but not worry about it until everything else is in order. That said, geometry is misbehaving a little... |
picking up frisbees isn't that hard. you just have a simple roller out infront of some polycarb and you can pick it up. Manipulating the frisbees to go into the shooter is a whole different story.
The geometry of this entire system and having it fit within that 54" cylinder has has given me sleepless nights and nightmares this season! We're playing 3 ideas at the moment, and hopefully the prototypes can show us something that I'm not seeing about what we can do. We've already been under the assumption that having the intake integrated with the shooter would take the longest, but if this isn't fleshed out by week 3, we're going to be in trouble. |
But weight considerations and the fact that frisbees go under bumpers quite easily makes it a strong consideration. Geometry and the fact that Frisbees are just so... Frisbeeish. |
https://sites.google.com/site/falcon...testing-videos |
#7
Excluding internal disc manipulation:
Picking up 1 disc at a time: easily doable on any robot design Picking up 2 discs side-by side: much harder due to constraints and lower room for error. But why would anyone want to do that? |
#8
#9
What are you doing about upside down frisbees?
#10
In auton the frisbees that are "free game" are line up side by side, why not pick up both at once? 7 frisbee auton in top goal = 42 points. Add in a 10 point climb and you just beat the teams that score 4 alliance disks in tower goal and climb high...and there is still teleop scoring to be had! Auton is key, like most years, and because of that, a frisbee pick-up mechanism should be strongly considered.
#11
#12
Robots without floor pickup will win events as captains or first round picks this year. I absolutely guarantee it.
#13
Probably. There are 50-something events. I'll bet you a team t-shirt that there are more alliance captains with floor pickup than without.
#14
My guess is that at one of our regionals, we will probably see about half the alliance captains with floor pickup, and the other will have one or two.
#15
