Go to Post To the best engineers, scientists, and thinkers, something that is "hard" isn't something to avoid; it is something that begs for us to prove that we can do it. STEM is built on the very idea of trying something, failing, and trying something different. - Bryan Herbst [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.82 average. Display Modes
Unread 17-01-2013, 23:56
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
ILikePizza555 is an unknown quantity at this point
Re: cRIO imaging tool hangs on "Rebooting cRIO"
Okay I got it all figured out now.
The process is a long one, so I might miss a few steps:
  1. The first thing I did was use the above link to reboot the cRIO into safe mode and unlock and reset the ip config
  2. Reset your computer's ip configuration to "automatic"
  3. Go to MAX, and check to see if the safe mode switch is enabled, if it isn't enable it. DO NOT USE THE IMAGING TOOL!
  4. Reboot the cRIO
  5. Open your favorite ftp client (I use filezilla) and upload the cRIO image manually (located in the same directory as the cRIO imaging tool)
  6. Go to the cRIO imaging tool, set your options, but make sure that the safe-mode switch is still on!
  7. Check "apply"
  8. Now, the cRIO's ip has been set back to 10.xx.yy.2, change the computer's IP setting back to normal
  9. Use FTP *again* to upload the latest firmware manually
  10. Now, you can use the Imaging tool to format the cRIO regularly
Hope it helps!
PONIES ARE STOOPID MAGIK -Heavy
