Go to Post The robot uprising is coming for your chairs first, people. - bobbysq [more]
  #31   Spotlight this post!
Unread 17-01-2013, 23:21
Joining the 900 Meme Team
FRC #0079
Re: Shooting Vs. Time hanging 30
Originally Posted by Ronnie314 View Post
Ya our districts will be the same more than likely. Michigan is hard though!
Anecdotally I want to agree with you but numerically the difference is not very big. The scoring distribution shifts to the right by a tiny amount.
  #32   Spotlight this post!
Unread 17-01-2013, 23:37
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Originally Posted by Zebra_Fact_Man View Post
If it's any help, I think that less than less than 10% of FIRST teams will be able to outscore a 30pt hang using a 10 pt hang and disc pts accumulated during the last 30 seconds, and only 40% of teams will be able to outscore a 20pt hang during the last 30 seconds with discs and a 10pt.
If you can 30pt hang, (for most regions) that will automatically win you 60% of your qualifying matches. That's why it's so restrictive to 30pt hang this year; because it's so valuable.
You don't have to necessarily outscore them in the last 30 seconds if they can only shoot 2 Frisbee and the rest of the time they focus on lining up for hanging or defense and in that time you can score 4-5 loads of 4 disc in the 3 pt goal, 2 during auto in 3pt goal, and a 10 point hang in last couple seconds that is a max of 82 points.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
  #33   Spotlight this post!
Unread 17-01-2013, 23:44
camalex3999 camalex3999 is offline
AKA: Cameron Alexander
FRC #3999 (The Shadetree Mechanics)
camalex3999 is an unknown quantity at this point
[/ATTACH]
Originally Posted by pfreivald View Post
A. It's a 60-degree pole.
B. Lots of teams will at least attempt the corner climb.
[ATTACH]13553
Actually its 68°.
Also I agree with your second statement. Our team is planing on climbing the side pole because we felt it would be easier.
  #34   Spotlight this post!
Unread 17-01-2013, 23:57
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Originally Posted by camalex3999 View Post
[/ATTACH]
[ATTACH]13553
Actually its 68°.
http://www.chiefdelphi.com/forums/sh...hlight=pyramid
I made a quick little spreadsheet for choosing where to hang. All you have to do is set how long you think it will take to hang on each level, and how long it would take to do a full cycle of picking up and shooting frisbees.
http://ge.tt/37zgzjV/v/0?c
It's really straightforward, it does assume you make all of your shots in the top goal with 100% accuracy. I don't know if it will be at all useful, but I already have it so here it is.
  #35   Spotlight this post!
Unread 18-01-2013, 00:18
I ment that it would be easier than the face of the pyramid. Sorry for not clarifying.
I do think shooting would be easier than climbing to the 3rd level, but if you can climb to the 3rd level than you would be a valuable alliance member. If you can climb to the top and put four colored disks in the top goal than you would score 50 points. If partner with an accurate shooter then they can shoot while you play defense then hang. Since your robot would not use the white disks there would be more for your alliance members.
I think the best alliances will be comprised of a climbing robot, a shooting robot, and a defense/feeder robot (to shoot disks to the shooter).
  #36   Spotlight this post!
Unread 18-01-2013, 00:24
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I don't think there has ever been a true/effective "defense/feeding robot". The best teams are usually the two best primary scorers that can team up with the best defense/secondary objective specialist left on the board.
  #37   Spotlight this post!
Unread 18-01-2013, 00:35
I think a 50 point climb robot and a very accurate shooter robot would be your primary scorers. If you have two shooting robots and no robot at the opposite end of the field that can feed the other two than they won't be able to put up too many points because they have to travel back and forth. My team was hoping to play the role of 50 point climb and feeder if we have enough time. The best alliance will have a dedicated climber, dedicated shooter, and dedicated feeder. This ensures that your feeder will have plenty of disks and can shoot often while the climbing robot scores 50. This theoretical alliance should easily clear 100 points if your climber doesn't mess up.
  #38   Spotlight this post!
Unread 18-01-2013, 00:36
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
[/ATTACH]
[ATTACH]13553
Actually its 68°.
Saying as how you were quoting a corner climb post, no.
Here's a picture to help everyone out. This is the updated pyramid CAD after FIRST had Autodesk fix it.
If you are climbing the outside of the corner (The first pic), this is the angle that really matters for you. You will be ascending at a 60 degree angle.
If you climb a face of the pyramid (e.g. NOT the corner) then you will be ascending at a 68 degree angle (2nd pic)
ID:	13554  Click image for larger version
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #39   Spotlight this post!
Unread 18-01-2013, 01:24
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I doubt many teams will be able to score 30 shooting points, even in all of teleop. On the other hand, almost no one will be able to climb for 30.
My analysis: if you can climb for 30 (ie, you are a powerhouse/strong team), it's worth considering. Most teams will not attempt to hang for 30, and that's ok. Some will be able to make up the difference by hanging for 10 and shooting well, but most will not. A bot that can hand and dump for 50 consistently will be effectively unbeatable in a 1v1 match against almost any other robot. A robot that can score in auto and can climb and dump would be hard pressed to lose a match.
In short, climbing is worth it, but it's still very, very hard.
-Plutarch
  #40   Spotlight this post!
Unread 18-01-2013, 01:50
Chris is me's Avatar
AKA: Pinecone
Both pure shooters and pure hangers have loads of strategic value in this game. I think teams should pick the one that plays best into their resources.
Can't wait to see the alliance selections for this year. I love games like this and 2012 where picking is so much more complex than "rank the robots in order of points scored".
  #41   Spotlight this post!
Unread 18-01-2013, 02:12
Undertones's Avatar
Undertones Undertones is offline
Drive Coach
AKA: Mac
FRC #4334 (ATA)
Undertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond repute
Also have to look at world final matches on Einstein. I cant recall a triple balance, teams went for 2 bots balancing or less and kept shooting.
There was at least one alliance able to perform triple balances on Einstein last year, but they were unable to complete a match with three working robots due to conditions far beyond their control.
Team 4334, Alberta Tech Alliance, Calgary Alberta
Western Canada 2016 Champions
Western Canada 2016 Creativity Award
Utah 2016 Champions
Utah 2016 Excellence in Engineering Award
Western Canada 2015 Innovation in Control Award
Utah 2015 Champions
Western Canada 2014 Regional Chairman's Award
Western Canada 2014 Champions
Utah 2014 Judge's Award
Western Canada 2013 Champions
Western Canada 2013 Innovation in Control Award
IRI 2012 Champions
Archimedes 2012 Champions - "The Eh Team"
GTR East 2012 Highest-Seeded Rookie
GTR East 2012 Cooperition Award
GTR East 2012 Rookie All-Star
  #42   Spotlight this post!
Unread 18-01-2013, 06:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think you guys are missing something obvious (we missed it kickoff day too).
If a team's robot opts for a 10-pt hang over a 30-pt hang, nothing says that the 20-point differential has to be made up in the last 30 seconds.
GitHub
  #43   Spotlight this post!
Unread 18-01-2013, 06:51
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
That is what I was getting at, you can make up for over half that in auto then one circuit and ur good!
  #44   Spotlight this post!
Unread 18-01-2013, 06:53
JesseK's Avatar
FRC #1885 (ILITE)
That is what I was getting at, you can make up for over half that in auto...
Or all of it plus change (well, one robot on the alliance can...).
GitHub
  #45   Spotlight this post!
Unread 18-01-2013, 07:07
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Ya if u have an alliance where u all can shoot and all hang for 10 in under 3 seconds and u have good autos u will beat any robot that just hangs and dumps in 5 pt goal
