Glad I have more than six weeks with you.
Unread 18-01-2013, 07:52
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Re: General LabVIEW questions from a VERY new user
Originally Posted by Greg McKaskle View Post
Rather than the stepwise adjustment, you may want to consider using square root. The attached image shows the plot from -1 to 1 and the code that preserves the sign of the square root of the input number.
Greg McKaskle
Thats a really smart idea that I hadn't thought of.. I'll definitely try it out at our next build day!
Just in case though, so I can have more to play around with, would someone mind explaining to me how to fix the pic above? I know the orange wires are double/numeric values and the green wires are boolean values, I just don't know how to set up an if-then-else-if sequence
EDIT: Also, another question.. Whenever I deploy code OR build the code, I get this pop-up every single time. I don't really understand what it means, but I just click okay and it deploys/builds perfectly fine. Should I just leave it alone or should I do something to stop it from popping up? (attached pic)
