Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 17-01-2013, 23:59
conishi808 conishi808 is offline
FRC #3008
conishi808 is an unknown quantity at this point
Pneumatic programming
Can someone tell me how to program 2013 Pneumatic and set it up?
Also, how do you program ultrasonic sensors?
Unread 18-01-2013, 08:19
Re: Pneumatic programming
Pneumatic & ultrasonic programming examples come with the LabVIEW installation.
Note: Not all ultrasonic sensors are the same, so different one's will code differently and some won't work directly with our system.
Look under the LabVIEW
Getting Started window -> Support -> Find FRC Examples...
Then look in the pneumatics or sensors folder for example programs that can also be run to test that your hookups are correctly done.
Here's another compressor example:
and a solenoid example:
Here's how a Maxbotix ultrasonic sensor would be setup:
