Go to Post After it took us weeks to machine sideplates for our 8WD, seeing their simple yet effective drivetrain was a huge "forehead slap" moment. - Chris is me [more]
Unread 18-01-2013, 10:08
Maddog_3407's Avatar
Maddog_3407 Maddog_3407 is offline
FRC #3407 (Mustybots)
Maddog_3407 is an unknown quantity at this point
Wind River Installation
I have been having issues installing Wind River. I re-installed Wind River this year and followed the instructions here. When I open Wind River, I am unable to set up a VxWorks Target or download Examples. There is also no FIRST Menu so I can't deploy or undeploy the program (I assume).
Error when I try to open an example
What I see when I try to setup a target
Here's what I have tried so far:
  • Re-installing several times
  • Installing the software on the NI CD
  • Installing the updates from firstforge
If anyone has advice for what I can try to do, it would be appreciated. No one else has Wind River installed on their computers. We have it on the Classmate, but I would rather not develop off of it.
Unread 18-01-2013, 10:14
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Wind River Installation
Did you uninstall the previous version on your laptop, or did you install over it? Also I want to double check, the instructions you followed on the install; did you scroll down to the existing installations section or did you start at the top?
Evan
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 18-01-2013, 10:20
I went down to Existing Installations because I had a copy (that worked ) from last year. I first tried installing over it. I have since uninstalled and installed a new copy.
Unread 20-01-2013, 11:18
I was able to find a solution, but it is not elegant. I copied all the files from the classmate with the working copy of Wind River to my computer. When I tried running things there were errors about a corrupted install, so I re-installed a couple of the VxWorks from the new CD.
I do notice that the FIRST downloader disappears when I run the update from firstforge. I have a backup of the .jar file. When I copy it back to the folder, the downloader appears again.
Very strange stuff, but it looks like it is working now.
Unread 20-01-2013, 14:38
TeraViks's Avatar
TeraViks TeraViks is offline
AKA: Brian Induni
FRC #3145 (TeraViks)
TeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the rough
I've have spent dozens of hours dealing with installing and setting up Windriver, and have found the following to be the best process to follow:
1. Turn off antivirus - THIS IS IMPORTANT!
2. Uninstall all previous versions of WR
3. Delete any remaining WR files AND the Windriver directory
4. Install both WR disks, regardless of 32/64 bit systems. MAKE SURE TO UNCHECK THE TWO BOXES AT THE END OF DISK 1.
5. Run the updates for FRC. There's a new one out for mid-season.
Hope this helps!
Brian
FIRST team 3145 (notice I'm doing Dean's homework!)
The TeraViks
Coeur d'Alene, Idaho
Unread 20-01-2013, 21:11
I think I did leave my antivirus on. I'll be sure to remember that next time. Thanks.
Unread 10-02-2013, 21:21
Thumbs up Re: Wind River Installation
I finally figured out the source of this error. In the command prompt, the path variable did not contain C:\Windows\System32. This prevented the updater from replacing all the files it deleted, since it depends on xcopy, a program in that folder. Once it was fixed, everything worked as it should.
