Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 18-01-2013, 13:24
JamesCulp JamesCulp is offline
FRC #3389
JamesCulp is an unknown quantity at this point
Exclamation Re: cRIO connection issue-can't deploy code
We had this issue on Team 3389 last weekend and it drove me nuts as the programming mentor.
We finally spent a few hours on the phone with NI on Monday and discovered there is a bug in the Smart Dashboard code currently. There are two workarounds, one of which I forget.
The work-around we are using is to shutdown the Dashboard app until AFTER you've deployed your code (via deploy or running from Robot Main.vi)
Since starting to use this work-around we've had no issues. I'm surprised this hasn't made it to an update or official blog post.
Hope this helps,
James Culp
Programming Mentor
Team 3389 RoboSpectrum
http://www.team3389.info/
