Go to Post On the one hand, I wouldn’t want to discourage innovation. But on the other, I would want to encourage simplicity. - Jack Jones [more]
Unread 18-01-2013, 13:24
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Ramp bot and level 1 climb?
One of our seniors is thinking we should put a ramp on our bot so that a robot that can only do a 10 point climb could ramp over us and hang on the second pipe for a 20 point climb. I do not think this will result in a legal climb as the hanging bot does not touch the pyramid at level 0.
Thoughts?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 18-01-2013, 13:26
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Ramp bot and level 1 climb?
I doubt it would be legal, based on what I read here:
http://www.chiefdelphi.com/forums/sh...hreadid=111454
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 18-01-2013, 14:01
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Thoughts?
Yes it's possible.
IF: Create a break in your ramp that allows the robot to brush the lower bar on its way up.
But don't do it
BECAUSE:
If you created a robot that could get a 10 point hang, and your partner does a 10 point hang, you will get 20 points also. If you can hang, then you don't have to rely on other bots to get your points.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 18-01-2013, 14:08
NotaJoke's Avatar
NotaJoke NotaJoke is offline
Future Engineer
Team Role: Scout
NotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud of
It is a lot harder than you think to convince your alliance partners to drive on top of your robot, regardless of how well you design the ramp.
You'd be better off spending resources to try and hang at the third level for yourself. The systems would be similar levels of complexity, and even if you can only pull off a level 2 hang you still earn the same number of points as you would have with a ramp bot.
Scout FIRST, ask questions later.
Unread 18-01-2013, 14:16
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Maybe.
For bots that could only hang 10, a 20-point ramp/lift is a very tempting pick if it's properly executed. There would have to be a way for the lifted bot's c.g. to remain close to the pyramid though.
I know we'd modify our bot to accommodate a good lift bot (appendage that touched the first rung) if that bot could climb for 10+ while lifting us for 20. Of course, we would want the lifting bot to prove itself to be stable, either on the practice field and/or on the field with a brave guinea pig. The 10climb/20lift combo may be easier for a team than a 20-pt self climb, depending on the team's resources and which design they come up with that's better.
The real difficulty will be doing a flexible design that can handle multiple drive train dimensions, shapes, and types.
GitHub
Unread 18-01-2013, 14:45
Andy A. Andy A. is offline
Getting old
FRC #0095
I had a similar thought early on, but aside from climbing sequencing rules, the 54" cylinder rule makes this pretty difficult to do. A 30" wide ramp, about what you'd need to ensure the majority of robots could comfortably fit on a ramp, would end up being about a 33 degree incline if you don't have a flat 'landing' on top of the bot. That's pretty steep for FIRST.
Depending on the length of the ascending robot and it's bumper configuration it's likely that most 'bots would get hung up and be unable to proceed. You might be able to 'help' by driving your own robot into theirs, but it becomes pretty hairy for a lot of reasons. The ascending bot is now also at a very different arrival angle to the horizontal bar it'd presumably hang on. Will it's mechanism work with that different geometry? Maybe, maybe not. I wouldn't want to bet on it.
Like I said, that's on top of rules regarding how a legal climb is preformed. It's a clever thought, but it seems like the climbing rules are designed to discourage/prevent it entirely. The intent is pretty clear- climb means climb, and there isn't any clear way to circumvent that.
Unread 18-01-2013, 15:33
Bruceb's Avatar
My thought was that this would be an illegal climb because the entire first pipe is in zone 1 not zone 0.
At least that is the way I read the picture
Section 3.1.5.2 figure 3-4 shows this, I think.
Unread 18-01-2013, 17:05
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
If I understand it correctly, this would be a legal 20 point climb. The climbing bot touches level 0 (the floor), level 1(the first bar) as it drives up your ramp and then level 2 (the second bar) when it hangs. As for whether it's a good idea or not, I'll leave that up to you.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 18-01-2013, 21:11
pfreivald's Avatar
AKA: Patrick Freivald
Most teams will barely trust themselves to lift their robot off the floor. Many fewer will trust another team to do so.
Not that it can't be done. In Rack N Roll we had some killer ramps that others used quite often (until 1511 totally killed our play, which we good-naturedly shake our fists at to this day), but it took some proving before others were willing to risk it.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
