Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Unread 18-01-2013, 14:45
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Values for Image Proccessing
Hello,
I'm trying to determine what values to replace the ones in the following line with.
BinaryImage thresholdImage = image.thresholdHSV(60, 100, 90, 255, 20, 255);
Any help would be appreciated.
We have never used vision processing before this year as a team and have decided to go with a green ring light.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 18-01-2013, 15:02
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Values for Image Proccessing
Originally Posted by inkspell4 View Post
Hello,
right now, this seems to be working pretty good for me
10,60,200,255,200,255
though this is our specific test field and im currently working on a system to adjust for light
Unread 18-01-2013, 15:17
inkspell4's Avatar
How did you determine what values to use for your system?
Unread 18-01-2013, 15:22
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
You should use the NI Vision Assistant to experiment with the numbers. You can see the results of the changes immediately on the screen. If you've installed the NI FRC tools on your computer, you should have it.
Start it up, choose "Acquire Image", choose "Axis Camera", fill in the IP info, and click the play button and you'll see your camera feed. If you click the single play button it will take a snapshot. Then click the last icon to "store the acquired image in browser". Then go to the Process Images page, choose the Color Threshold tool, select HSV, and then you can tweak the numbers there and see exactly what it would do to your image.
You can, of course, add multiple processing filters along with the final particle report - exactly the same as you would in your program.
Keep in mind that in Java you don't have access to all the different tools that are shown in the Vision Assistant.
Dale
Unread 18-01-2013, 17:16
inkspell4's Avatar
What range of values should i start out with.
We are using a green ring light as mentioned before
Unread 18-01-2013, 18:36
inkspell4's Avatar
Is it likely that there will be noise/small particles that stray after the threshold is done.
Unread 18-01-2013, 18:44
Have you read the Vision Processing paper? http://wpilib.screenstepslive.com/s/3120/m/8731
Unread 18-01-2013, 19:20
inkspell4's Avatar
Yes i have read the linked document but could not find much info on the threshold values
Unread 18-01-2013, 22:11
These are the numbers for minH, maxH, minS, maxS, minV, and maxV. The best way to determine the numbers is to use your LEDs, your camera settings, and either debug using pixel values in your code, or open it in a tool such as NI Vision Assistant and see what the values are.
Without seeing your images, I'd say you should probably start with maxH higher, say at 125 or so. You should also lower minH from90 to 40 or so. Then work the mins higher and the MaxH higher until you eliminate other particles.
Greg McKaskle
Unread 18-01-2013, 22:55
inkspell4's Avatar
Which tool in vision assistant should i use for testing and finding the values
Unread 18-01-2013, 23:37
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
In NI Vision Assistant, load the sample script they give you.
Acquire an image by connecting to your camera and using the Acquire Image button (enter IP and settings).
In the Color Threshold, adjust the values until your goal is red (and nothing else is). Those are your HSV values that you want to put into your program.
Unread 18-01-2013, 23:40
inkspell4's Avatar
I thought you wanted everything but your goal to be red
Unread 18-01-2013, 23:45
Programming
Yeah that's what I thought too at first, but apparently not. The red part is what you want.
Ideally you'd see a border of red around some black (goal hole), then everything else is black. Then, if you go down the steps (beyond the color threshold), you should see the goal get entirely filled in with red, and the small particles get eliminated.
Here: http://wpilib.screenstepslive.com/s/...ng-the-targets
RTFM (Read The FIRST Manual)
Unread 18-01-2013, 23:53
inkspell4's Avatar
Oh i get what your saying i was think of it in terms of the preview color when applying the threshold in vision assistant not as the image afterwards
Unread 18-01-2013, 23:55
Programming
Yeah it's our first year doing image processing too.
We also had some problems with the provided sample code (java) detecting distance, so we're in the process of writing our own distance computing method.
