Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 16-01-2013, 21:42
s127221 s127221 is offline
FRC #2994
s127221 is an unknown quantity at this point
FIRST Workbench Updates Wont Work
Hello all,
For the last several days, I have been struggling to successfully install the 2013 C++ updates to my laptop. I successfully manage to install both Workbench discs, but the update for all the FIRST components never works. No menu bar, WPILib templates, or other components with the update. I looked at my subdirectory C:\WindRiver\workbench-3.3\wrwb\wrworkbench\eclipse\plugins and noticed a lack of the file edu.wpi.FIRSTDownloader_1.0.0.jar that should have come with the update. However, once I manually copied the file from a teammate's computer, my FIRST menu bar appeared. Moreover, when I ran the update again, the file in the plugins directory that I just mentioned disappeared. Would it just be easier to manually find and copy all the associated update files to their respective directories? Any tips on how to resolve this would be greatly appreciated.
Unread 18-01-2013, 00:11
wlmeng11's Avatar
wlmeng11 wlmeng11 is offline
FRC #0008 (Paly Vikings)
wlmeng11 will become famous soon enough
Originally Posted by s127221 View Post
Hello all,
You installed this right?
http://firstforge.wpi.edu/sf/frs/do/...874E3B90C9F96D
Unread 18-01-2013, 02:16
matthewkennedy matthewkennedy is offline
FRC #1294 (Top Gun)
matthewkennedy is an unknown quantity at this point
Re: FIRST Workbench Updates Wont Work
I'm having exactly the same problem. The WPIlib libraries are present, in addition to the FRC project templates. I've installed the binary at the link. edu.wpi.FIRSTDownloader_1.0.0.jar is present where it's supposed to be. I can build/download/run/debug projects to the cRIO just fine, but I can't deploy them as startup.
-Matthew
"The future is already here—it's just not very evenly distributed"
-William Gibson
Unread 18-01-2013, 20:04
AKA: Brad
#0190 ( Gompei and the Herd)
Are you setting the FIRST Downloader Preferences? You have to set that preferences page (team number AND .out file location), then use the FIRST/Deploy menu item when you're ready to deploy it. See the directions here:
http://wpilib.screenstepslive.com/s/...ct-to-the-crio
Brad
Brad Miller
Robotics Resource Center
