Go to Post Only a few more days till i get to see her again! This is sad you would think I was talking about a chick... no wonder my gf gets jealous. XD - sportzkrazzy [more]
Unread 15-01-2013, 18:14
NegaNexus NegaNexus is offline
AKA: Thys Ballard
FRC #2130 (Alpha+)
NegaNexus is an unknown quantity at this point
Compressor
Hello, I am from the TeraViks #3145. As of right now, we're stuck. We are stuck on programming the compressor to work. Please help us with any information you have on this predicament. Thanks! Sample:
#include "WPILib.h"
class RobotDemo : public SimpleRobot {
	Compressor *compressorPointer;
	public:
		RobotDemo() {
			compressorPointer = new Compressor(4, 2);
			compressorPointer->Start();
		~RobotDemo() {
			delete compressorPointer;
Unread 15-01-2013, 21:25
Re: Compressor
What do you expect to happen? What is happening instead?
Unread 15-01-2013, 21:39
AKA: Thys Ballard
FRC #2130 (Alpha+)
Re: Compressor
It does absolutely nothing. It is supposed to start, and then we'll do further testing.
Unread 15-01-2013, 22:20
Re: Compressor
How exactly do you have the compressor and pressure switch wired? Be as detailed as you can.
Does anything work on the robot -- any motors or relays?
Unread 15-01-2013, 22:40
AKA: Thys Ballard
FRC #2130 (Alpha+)
Re: Compressor
Unread 16-01-2013, 01:32
AKA: Thys Ballard
FRC #2130 (Alpha+)
Re: Compressor
I have no idea why there are two of the same posts, but anyway. They are plugged it to relay 3, digital I/O 4. Everything we tested so far works besides the solenoid and compressor.
Sent from my Nexus 7
Unread 16-01-2013, 07:42
Re: Compressor
That's not nearly enough detail for me to give troubleshooting advice. Which individual pins of the Digital Sidecar are connected, and to what? The compressor has two power wires; where do they go?
Pictures would help.
Unread 16-01-2013, 10:42
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Compressor
Your sample code states the compressor is digital i/o 4, and relay 2, you say you are using relay 3; is that your issue?
Try calling compressor->Start() in your teleop/autonomous loop.
The code you presented is fine otherwise, though I would opt to directly instance compressor, rather than allocating it dynamically, but it's a point of preference. I also prefer to derive from IterativeRobot instead of SimpleRobot
class Robot2012 : public IterativeRobot
Compressor compressor;
public:
Robot2012(void):compressor(DIGITAL_CHANNEL_1_INPUT_COMPRESSOR_SWITCH, RELAY_CHANNEL_1_COMPRESSOR_RELAY)
void DisabledInit(void)
    compressor.Stop();
void AutonomousInit(void)
     compressor.Start();
void TeleopInit(void)
     compressor.Start();
Here's a link to my 2012 code: https://github.com/TeamExcel/Project.../Robot2012.cpp
Unread 16-01-2013, 18:31
AKA: Thys Ballard
FRC #2130 (Alpha+)
Re: Compressor
I didn't post the updated code, which has (4, 3) now. Sorry about that. It still won't work either way. To Mr. Anderson, I'll get a picture to you tomorrow.
Thanks,
Thys
Unread 19-01-2013, 00:49
AKA: Thys Ballard
FRC #2130 (Alpha+)
Re: Compressor
We fixed it. Thanks for trying though.
Unread 19-01-2013, 09:00
Re: Compressor
Would you mind telling us what the problem was and what you did to make it work? Others might have similar problems, and your solution might help them.
Unread 20-01-2013, 14:43
TeraViks's Avatar
TeraViks TeraViks is offline
AKA: Brian Induni
FRC #3145 (TeraViks)
TeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the rough
Re: Compressor
On behalf of NegaNexus (one of my programmers), thank you to all who helped. This was one of those instances where we had a few different issues that makes troubleshooting extremely difficult and frustrating.
Here's what we found was the cause of our issues:
1. We had a flaky network cable!
2. We had a flaky Windriver install (or some setting was changed that shouldn't have been)
Once we got in to a methodical test & record results process, we were able to diagnose the bad network cable. This then led to changing to a different computer with WR and all systems worked as they should.
Brian
FIRST team 3145 (notice I'm doing Dean's homework!)
The TeraViks
Coeur d'Alene, Idaho
