Go to Post Don't test your autonomous on the comp field. There's a practice field for a reason. - DampRobot [more]
Unread 18-01-2013, 19:47
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
LabVIEW Source Control
I'm still new to source control, and the other threads I've seen haven't been helpful so far.
Team Fusion is setup in a classroom at Gulfport High School. We're not allowed to connect our computers to the school's network, so that also means no internet (bye bye github, bitbucket, and all the other great repositories). I'd like to implement some time of source or revision control for our code. We would have to setup a PC with some type of subversion server.
At NASA, we used TortoiseSVN on top of Windows to hold our code. That's possible, but it doesn't integrate with LabVIEW very well. I'd like to be able to compare, merge, and do all of the other normal source control system functions (push, pull, merge, commit) with LabVIEW files.
So the question is, what does your team do?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 18-01-2013, 20:43
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: LabVIEW Source Control
Our (very unprofessional) way is just to duplicate the project folder and rename it whenever we are about to make a significant revision to the code. Last year we ended up at Competition Code v5.lvproj.
Unread 18-01-2013, 21:07
This blog seems pretty full on info.
http://forums.ni.com/t5/LabVIEW/LabV...t/true#M607335
Greg McKaskle
Unread 19-01-2013, 03:55
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
This year our team's programming mentor suggested setting up some sort of version control system, so we went with SVN.
TortoiseSVN is our preferred client. It preforms all of the functions you said it doesn't (merge, visual diff, push, commit, update). The people who head the Tortoise project also have an SVN monitor tool to alert you to new commits by polling the SVN server every x number of minutes.
Tortoise's integration with LabVIEW was nearly plug-and-play. The only thing that required a little bit of effort was selecting the visual differencing VI from the correct directory.
Dom
Unread 19-01-2013, 15:40
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Or, since nearly everyone now adays has a smart phone turn on someones tether mode or wifi hotspot and link the computers to the internet that way.
