Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Unread 13-01-2013, 19:22
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Powering the Raspberry Pi
For those of you with experience, how would you power the Raspberry Pi on your robot?
For those without experience, it is a small, cheap computer that runs on a microUSB cable, drawing 700mA @ 5V.
We need to power a camera as well, which is currently using the 5V port at the bottom of the PD board. Can we just splice the Raspberry Pi on?
Unread 13-01-2013, 19:57
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Powering the Raspberry Pi
I'd use the 12v-5v converter to power the unit. The converter gives 5A, more than enough to run the Pi. The port on the distribution board gives out 3A, but with the camera on it, you have less than an amp left over. I've been running Pi's for awhile, they want a rock solid 5 volts, and 800ma to do high levels of computation, like video routines.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-01-2013, 22:20
Mr_smith's Avatar
Mr_smith Mr_smith is offline
FRC #3979
Mr_smith is an unknown quantity at this point
I would be careful interfacing with the RPi, though. Micro usb powers the board with 5V in, but voltage drops to 3.3V and most of the chips on the board are regulated at 3.3V. In/out pins are unprotected, meaning that if you put a 5V signal on a pin, you might fry the pin.
Unread 13-01-2013, 23:05
dtengineering's Avatar
AKA: Jason Brett
I'd just hook it up as a custom circuit.
Consider... you've got all sorts of 12V power available on the power distribution board. Throw a 20A breaker into one of those ports and get a "car charger" for a cell phone and you're done.
Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.)
Jason
Unread 14-01-2013, 00:41
Kyle R Kyle R is offline
FRC #4246 (Resurrected Robotics)
Kyle R is an unknown quantity at this point
We are using Raspberry Pi's for our vision processing. To power them I made a custom power supply PCB with USB connectors to power up to 5 RPi's. If you want I can send you the files for it.
Unread 14-01-2013, 05:48
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
Won't the 5V converter already be powering the D-Link? Or can it provide for both?
We're only using power and ethernet. But I'll keep that in mind.
We don't have equipment to build PCBs Are they commercially available?
Unread 14-01-2013, 08:51
Sorry, I was trying to say use the 12->5v converter that AndyMark sells. It's inexpensive, has amperage capacity, mounting holes, and lets you put the converter on it's own breaker. Then there is never any question about power to the Raspberry Pi. It's also not a cheaply made part, it will stand up to the banging around that a robot takes during the season.
Unread 19-01-2013, 07:20
ohrly?'s Avatar
Griffin Alum
AKA: Colin Poler
Awesome!
Turns out it has more than enough amperage for the network adapter and the Raspberry Pi. But the darn rules say that the raspberry pi cannot share the same power converter.
EDIT: It says that the no other load may be connected to the terminal at the bottom. Does this refer to the wireless bridge (which I assumed) or the 12v-5v power converter (which means anything could be attached to its 5v terminals)?
Unread 19-01-2013, 09:23
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I believe they are saying to buy another converter and simply connect it like you would anything else to the distribution board under a 20amp breaker.
