Go to Post "FIRST is like a pizza, we all think different toppings should be on it" - Andrew Schreiber [more]
Unread 19-01-2013, 09:17
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Exclamation Labview Activation
How do I activate my version of LabView? I have only gotten it into evaluation mode
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 19-01-2013, 09:22
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Labview Activation
The activation key is on the screenstepslive document for installing LabView
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 19-01-2013, 09:43
katsauga's Avatar
Lead Programmer
what?? I dont know what that is
Unread 19-01-2013, 09:48
Go to Start -> All Programs and look under National Instruments for the NI License Manager to activate your products.
The license code you should be using is S14X86763
Unread 19-01-2013, 10:49
katsauga's Avatar
Lead Programmer
Talking Re: Labview Activation
thank you so much! its working now
Unread 19-01-2013, 11:44
Most of the control system documentation has moved to a website called screenstepslive. https://wpilib.screenstepslive.com/s/3120
In particular, you need Installing LabVIEW for FRC 2013
Unread 20-01-2013, 11:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Where did you find this code?
The packet I have lists S/N M77X14459 as the serial number on the back, which doesn't work in the activation wizard (although it sends me an email saying it worked, with an activation code which doesn't work).
The SN you listed is correct, it just worked for me.
Kettering Motorsports
Unread 20-01-2013, 11:22
Due to a manufacturing mistake, the DVDs sleeves were given unique serial numbers rather than a common one. The licensing was setup for a single serial number, not a long list.
The correct SX serial number was printed on a card that was in the packet, but it is in a rather small font. These were built overseas and by the time it was discovered there was not time to correct it.
It has been a bit support issue, as you can imagine.
Greg McKaskle
Unread 20-01-2013, 11:35
Here's what the card Greg mentioned with the correct FRC activation code, included in everyone's LabVIEW envelope, looks like.
See the tiny print in the lower left hand corner.
Unread 20-01-2013, 14:25
The correct number is also in the detailed step-by-step instructions for installing LabVIEW.
