Go to Post ...if you don't ask, you won't get. - Billfred [more]
Unread 01-19-2013, 12:20 PM
Defensoft3585 Defensoft3585 is offline
Programming Captain
AKA: The Defenestrator
FRC #3585 (Rogue Robots of 4H)
Defensoft3585 is on a distinguished road
Re: CIM programming question
The motors can't go at separate speeds, since they are mechanically linked together.
If the two motors on one transmission are each getting a slightly different voltage from their respective Victors, or if they are getting the exact same voltage but one motor is slightly less efficient than the other, then what will happen is this: the motors will both be going at the same speed, but one of the motors will be carrying slightly more of the load than the other because it is providing slightly more torque. This does not break the transmission.
Thank you very much Ether. This clears it up for us. Just wanted to be careful - last year out transmission flopped out on the floor during several matches
