Go to Post I get in enough trouble mentoring one team. If I did five teams I'd be less one wife. - Koko Ed [more]
Unread 19-01-2013, 13:26
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Exclamation Labview Problems
For some reason, whenever i try to open a labview VI, The RT Compact rio Target gives an error saying "The plug-in for the selected item is not installed on your system or the plugin has an expired license. please contact National Instruments."
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 19-01-2013, 13:28
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Labview Problems
Press start and launch the "NI Update Service", more than likely you haven't installed the updates for Labview. Then install the FIRST Software updates.
CTO/Head Programmer of Team 1710
Unread 19-01-2013, 13:30
katsauga's Avatar
Lead Programmer
it cannot connect to the internet. its ip is configured for the robot.
Unread 19-01-2013, 13:36
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Press start, type "Network and Sharing Center", Enter. On the left side, click "Change Adapter Settings", Select the adapter that you would like to use to connect to the internet, right click it, "Properties". In the list menu, choose "Internet Protocol Version 4" Then Click Properties. Change the Radio button to "Obtain an IP address automatically" Okay out of everything and connect to the wifi, or connect your internet cable.
Unread 19-01-2013, 13:49
katsauga's Avatar
Lead Programmer
it said there was an error connecting to national instuments
Unread 19-01-2013, 15:26
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Do you have a firewall or AV on? If so turn it off, including the firewall in widows, Retry Connecting The Update Software.
Unread 19-01-2013, 16:14
katsauga's Avatar
Lead Programmer
kk, it worked. the problem was the PC was running at max and did not have room for data
Unread 30-01-2013, 15:36
Program Spartan's Avatar
Program Spartan Program Spartan is offline
Current Vice President of Team 168
AKA: Nathan
FRC #0168 (MIB (Mechanical Investigation bureau))
Program Spartan is an unknown quantity at this point
I believe that I have the same problem except for my LabVIEW is up to date with all software downloaded.
Robots of the future:
"This can be made if we put our minds together to overcome failure (and if we have a lot of money)".
-Nathan J. Hagood
Head Programer
Electrical Intermediate
