Go to Post Andy Baker told me this one: "Do what people wouldn't talk about when you win the nationals."- Nuff Said - Matt Attallah [more]
Unread 19-01-2013, 14:06
EyalD EyalD is offline
FRC #1943
EyalD is an unknown quantity at this point
Using the Magnetic Encoder
Hello!
This year we decided to try out the magnetic encoder (model AS5145B)
so before we try it we need to find out exactly how to wire it so we won't do something wrong and destroy it.
In addition, we'll really appreciate an instruction on how to set it up and use it with a motor (Cim for example).
Thank you very much!
Unread 19-01-2013, 14:08
Re: Using the Magnetic Encoder
Originally Posted by EyalD View Post
Hello!
https://wpilib.screenstepslive.com/s...control-system
Unread 19-01-2013, 14:10
PID tutorials
https://decibel.ni.com/content/docs/DOC-14709
http://www.controlguru.com/pages/table.html
http://www.inpharmix.com/jps/PID_Con...ms_Robots.html
http://www.chiefdelphi.com/forums/sh...2&postcount=12
http://brettbeauregard.com/blog/2011...-introduction/
http://www.education.rec.ri.cmu.edu/...edmovement.pdf
Unread 19-01-2013, 14:47
FRC #1943
Thank you! But I actually meant to ask: how do I physically attach the magnet to the CIM motor?
Unread 20-01-2013, 20:38
What is the CIM motor attached to ?
Unread 20-01-2013, 23:55
sg999 sg999 is offline
Programming Lead, Co-Captain 2013
AKA: Bella
FRC #0999 (Mecharams)
sg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to behold
I'm not sure what other teams are doing (or even how we're supposed to be mounting the encoders), but we're using one motor per gearbox, so someone on our team is machining a mount for us to attach the encoder to where the other motor is supposed to go. We're also enlargening the hole in the magnet, so we can just stick the magnet right onto the shaft.
There is always time-whether or not you use it productively is up to you.
2012-WIWI 6th seed (Thanks for being awesome alliance partners, 1991 and 178)
2014-present College student at Caltech (math/CS)
Unread 21-01-2013, 00:01
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
So, to my understanding, the magnet is supposed to be mounted on a shaft (CIM motor shaft/output shaft/etc) and then the chip is supposed to be placed just a millimeter in front of the motor?
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 21-01-2013, 00:06
Draw a sketch to illustrate what you think your words are saying.
This will avoid much misunderstanding.
Unread 21-01-2013, 00:14
ksafin's Avatar
AKA: Kirill Safin
Unread 21-01-2013, 00:22
AKA: Bella
Correct, except you are allowed to be in a range of .5mm to 1.5mm, according to the sheet that came with the encoder.
Unread 21-01-2013, 00:30
ksafin's Avatar
AKA: Kirill Safin
Seems much more difficult to put on than the USDigital Encoders..
Unread 21-01-2013, 00:41
ID:	13592  Click image for larger version
Unread 21-01-2013, 09:31
What gearbox are you using? Ones from AndyMark have an extension to the output shaft that's designed for mounting the E4P quadrature encoders. You could put your magnetic sensor there.
Unread 21-01-2013, 10:19
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
We're using these encoders also. I almost Guarantee you you're suppose to mount them to the gear box. not the motor shaft.
I am trying to mount this encoder to a Ball shifter right now, hope it works out.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 21-01-2013, 15:53
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
For what it is worth, if you look at the AS5145B data sheet, in Table 4 (Magnetic Input Specifications) it gives a maximum frequency of rotation of 153 rpm. I would be wary of putting that on the output of a CIM, but I could be interpreting the data sheet incorrectly.
