Re: camera not showing
This may sound stupid, but I spent 2 hours trouble shooting and I just typed the ip wrong in the SmartDashboard, is your ip right?
Is there any chance you could send me your entire SmartDashboard folder? (Extensions and all) I'd like to see if it is simply a build related issue. |
Has anyone had any luck getting this to work? We're still without camera in our SmartDashboard.
Also I tried to use a modified camera widget displaying a crosshair, and that also did not work. There was also an update to FRC tools, but it did not fix anything with the camera problem.
Check what the fps is for the stream. We had an issue where SmartDashboard Camera did not work if it got a fps under 30.
#7
Where exactly is this setting? I couldn't seem to find one in the Camera's setup portal.
#8
I'm having the same problem with the Smart Dashboard. Default Dashboard shows the camera image just fine, so I believe that indicates the camera is configured correctly. SmartDashboard does not connect to the camera.
In addition, if I launch the SmartDashboard from the driver station I don't see any of the extensions widgets when I try to add a new object. If I launch the SmartDashboard directly using the SmartDashboard.exe executable all of the extensions show in the list. Camera still doesn't connect. I thought this might indicate an install problem, but I can't correct it, even after a reinstall. If anyone has figured out how to correct these issues, your help would be appreciated. |
#9
In order to be able to add the Camera to smartDashboard, you'll need to download the WPILibCameraExtension and place it in C:/ProgramFiles/SmartDashboard/extensions.
Then, just open SmartDashboard, click View, and Add, and the Camera Option should appear. You can get the WPILibCameraExtension here: https://www.assembla.com/spaces/tech...ware/documents Click the first file. Hope this helps. |
#10
Extension was already present. Its part of the SmartDashboard Installer_1.0.4 that also installs the WPIJavaCV and openCV libraries
#11
Can you be sure that you:
Both of these steps are illustrated on this page: http://wpilib.screenstepslive.com/s/...sion-installer Brad |
#12
I have the same problem, but mine works when I have it connected through ethernet. Then sometimes it works with it connected to the bridge, but if I connect the bridge to the cRIO the camera feed shuts off in Smart dashboard.
#13
What I noticed was the SmartDashboard installer v.104 (or something with a 4 in it) gave me many problems until I installed the v.5(or something with a 5 in it) then it got me able to use two cameras simultaneously. Big problem though was at competition out camera feed shut down the whole playing field and we couldn't play because of the massive bandwidth the cameras took. So in the end we had to resort to labview for camera feed.
#14
