Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 19-01-2013, 14:38
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Utilizing the Smart Dashboard
Originally Posted by SuperMario View Post
My team's idea for #4 was to save the processed image to the computer and have the smart dashboard read that file, but I don't know how to get the SmartDashboard to read an image.
i dont know how to get an image D:
btw i fixed the preferences issue.. it turned out that i had 10 preferences windows stacked ontop of eachother -_-
Unread 19-01-2013, 20:24
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Originally Posted by Arhowk View Post
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.wpilibj.templates.buttons;
import edu.wpi.first.wpilibj.buttons.Trigger;
import edu.wpi.first.wpilibj.command.Command;
 * @author Arhowk
public class t1684_SD_TakeImage extends Trigger{
    public boolean get(){return true;}
    public void whenActive(Command command){
        System.out.println("meh");
    public void whileActive(Command command){
        System.out.println("meh2");
    public void whenInactive(Command command){
        System.out.println("meh3");
this displays the button on the dash but wont do anything when clicked...
still getting above error
That's not how you use it.
Trigger doThingyTrigger;
doThingyTrigger.whenActive(new DoThingy()); // DoThingy is some class extending Command
SmartDashboard.putData("Do Thingy",trigger);
I'd put this in robotInit, but it can be almost anywhere.
I code stuff.
Unread 20-01-2013, 15:06
AKA: Brad
#0190 ( Gompei and the Herd)
What.... i posted and it said a moderator has to approve the thread and its still not there....
anyway, if it finally does show up, heres the exact error whenever i try to use the Preferences class
[cRIO] Done Reading
[cRIO] task 0x111b458 (FRC_cameraTask) deleted: errno=0 (0) status=0 (0U)
[cRIO] ncaught out of memory error on thread  - aborting isolate Server Connection Reader Thread
[cRIO] Tried to execute callbacks in the context of an isolate that is no longer alive: isolate 1 "edu.wpi.first.wpilibj.templates.RobotTemplate" (EXITED)
[cRIO] Skipping that set of callbacks
[cRIO] task 0x1126ed8 (cached TaskExecutor 1) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO]
[cRIO] --------------------------------------------------------------------
[cRIO] GCs: 1 full, 4 partial
[cRIO] ** VM stopped: exit code = 999 **
[cRIO] task 0xd1f738 (SquawkRobotTask) deleted: errno=0 (0) status=999 (0x3e7)
BUILD STOPPED (total time: 59 seconds)
e/ i guess santas not coming.
I get the above error when trying to use the Prefrences class... other stuff was just blabble
Just found the error that you are showing here. It is a bug in the Preferences class in WPILib. There is a fixed version of it in Stable (not Release) release of WPILibJ. Can you try updating your plugins to the Stable version by editing the plugin location and changing "Release" to "Stable" in the URL? Let me know if it work for you.
Also, there is an example of using the Preferences class here:
http://wpilib.screenstepslive.com/s/...smartdashboard
Thanks
Brad
Brad Miller
Robotics Resource Center
