Go to Post Who needs weapons when you have a scary face - Conor Ryan [more]
Unread 19-01-2013, 11:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Using Network Tables
Can I send this line
ColorImage image = camera.getImage()
to a folder on the driver station?
Unread 19-01-2013, 11:53
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Using Network Tables
NetworkTables doesn't send large data items like images from the robot to the laptop. However, if your goal is to process the image on the driver station computer, you can connect the camera to the switch on your robot and just open it from the laptop. There are several ways of doing that. You can write a program with RoboRealm for doing the image processing. You can write your own program using some library like OpenCV or the NIVision library, or you can make a SmartDashboard plugin that does the image processing.
If you want to do the vision processing on the robot, then there are some sample Java programs for robot-side target detection in NetBeans.
Brad
Brad Miller
Robotics Resource Center
Unread 19-01-2013, 14:39
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
e/ Changing the focus of this thread!!
Whenever im using RoboRealms, I can add the Network Table widget to the current setup, set the ip to 10.16.84.2, set the default camera to none, but when i run the program its not going to the axis camera on the robot its booting my webcam!
Options>Video>Camera only has two settings, Nothing and my camera. (default to nothing)
Unread 19-01-2013, 15:09
SuperMario SuperMario is offline
FRC #3692
SuperMario is an unknown quantity at this point
I'm not sure what you are asking, but you can access the ip of the camera and see the feed from any computer.
Unread 19-01-2013, 16:55
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
You have to use the AxisCamera module on RoboRealm. That is the only way I know of you are going to get a feed on RoboRealm.
Unread 19-01-2013, 16:56
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
k, nevermind, thread derail again... (Forgot to add the axis intenet camera module)
how do i instantiate a network table?
cameraTable = NetworkTable.getTable("RoboRealm");
gives me an error
Illegal State Exception : network table already initialized
(if i catch the error, it does nothing)
e/ nevermind.
current problem =
public void testPeriodic() {
        enabledPeriodic();
        NetworkTable server = NetworkTable.getTable("SmartDashboard");
	try
			System.out.println(server.getNumber("IMAGE_COUNT", -1.0));
	catch (TableKeyNotDefinedException ex)
continually prints -1
my robo builder setup:
Axis_Internet_Camera 10.16.84.11
Threshhold 200-255 (sat)
Fill 500
Convex Hull
set IMAGE_COUNT = /SmartDashboad/IMAGE_COUNT
Network_Tables (port 1765, ip 10.16.84.2, send : IMAGE_COUNT)
Unread 19-01-2013, 17:42
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
So... is there a way to have the Roborealm server process the Axis camera images, then send those images to the SmartDashboard so that we can see the processed output?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 19-01-2013, 17:53
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
You can try using the TableViewer to ensure that the key that you are expecting is actually in NetworkTables. You can find it in C:/Users/YOURUSERNAME/sunspotfrcsdk/tools/TableViewer-VERSION.jar
This will allow you to connect to a networktables server and view the raw entries.
Unread 19-01-2013, 18:41
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
what. why would you want to do that.
(yes, just have roborealm save to a file than have smartdashboard read to file)
Your right... the entires arent there... but IMAGE_COUNT (in no subfolder) is
Unread 21-01-2013, 14:06
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
bump...
set IMAGE_COUNT = /SmartDashboard/IMAGE_COUNT
in RoboRealm isnt working and it keeps saving to IMAGE_COUNT. What would the proper configuration be for seting IMAGE_COUNT to /SmartDashboard/IMAGE_COUNT OR can i get IMAGE_COUNT from the crio root?
(to rehash the thread)
Unread 21-01-2013, 15:24
MagiChau's Avatar
AKA: Michael Chau
bump...
you have to set /SmartDashboard/IMAGE_COUNT = IMAGE_COUNT
The left side is for the variable you are setting. The right is for setting the value of that varaible.
Unread 21-01-2013, 18:02
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
... almost there....
ok i got that. it didnt work. than i sent /SmartDashboard/IMAGE_COUNT and it *almost* worked.
It sent it once. but thats it. it will NOT overwrite the values. it will create them and send them but not overwrite
using Set_Variable, i set GG = 123
i sent GG
TableViewer says GG = 123
i set GG = 234 (in RoboRealm)
i send GG
i make a new variable GG1
i set GG1 = 234
i send GG1
TableViewer says GG1 = 234, GG = 123
Unread 22-01-2013, 14:24
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
bump
Unread 22-01-2013, 18:37
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
ok it seemed to work by installing the mid-season update but now it refuses to send arrays!
i can send whatever values i want but I put in the blob filter and tried to send BFR_COORDINATES and nothing was sent. i can swap it out for something like IMAGE_WIDTH or IMAGE_COUNT and it sends just fine but just nothing sends when i send BFR_COORDINATES
on the other hand, how do you send arrays via NetworkTable anyway...
Unread 23-01-2013, 02:37
RoboRealm RoboRealm is offline
FRC #0443
RoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the rough
If you have trouble sending arrays you can always use the Set_Variable module and set something like
/SmartDashboard/coord1x
to
BFR_COORDINATES:0
i.e. 0 is the first value of the BFR_COORDINATES. Likewise BFR_COORDINATES:1 would be the second (coord1y) and so on. Assuming you only want to send the first 4 coordinates this is a possible way to itemize each of the array values and send them individually.
STeven.
