Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Unread 19-01-2013, 17:09
Jengles's Avatar
Jengles Jengles is offline
FRC #4753 (Bexley Lions)
Jengles will become famous soon enough
Simple (so i think) motor mounting question
We are having some difficulty mounting a cim motor directly to a pneumatic wheel. We have the cim motor, pneumatic wheel, key hub from andy mark, key hub mounting kit also from andy mark, and the key stock to properly fit. We put the key stock in so the motor and wheel spend together. But what are we suppose to do to keep the wheel from lifting up? Thanks.
Unread 19-01-2013, 17:12
Re: Simple (so i think) motor mounting question
What's the application?
The simple answer may be to support the other side of the wheel, say with a connecting axle to the CIM's axle, or support the back of the motor as well. OTOH, the simple answer may be to use some other method entirely. Depends on the application.
Unread 19-01-2013, 17:15
Jengles's Avatar
If we are using the wheel as a one wheel shooter like found in this other team's video http://www.youtube.com/watch?v=ARUhI8Qob5w , what keeps the wheel from falling down and off? (Or in our case flying up, since our motor is underneath?).
Unread 19-01-2013, 17:39
DonRotolo's Avatar
Back to humble
FRC #0832
Usually, one would use fasteners (such as 6 screws) to hold the wheel (which has 6 holes near the center, yes?) to the shaft coupler (which should also have 6 matching holes).
See this item, see how it has 6 holes in it?
The see how this item also has 6 holes? These should match up, and a bolt goes through each one.
Unread 19-01-2013, 17:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I guess you are asking how to keep the hob from coming off the shaft?
You can put set screws on the hub. The shaft of the cim is threaded. A screw and a washer is a possibility.
If you are using the bearings in the motor to locate everything, You have a large overhung load on the motor. Bending the motor shaft is something to be concerned about.
Unread 19-01-2013, 18:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We ordered a hub like that, and I expect that what we will do is to drill and tap it for a set screw (probably 10-32), and file a flat on the motor shaft. The screw would probably be opposite the key, possibly 90 degrees away from it...??? although it probably doesn't matter. I've seen some industrial pulleys with a set screw on the keyway, too.
We are probably going to use a chain drive so we can play with the speed of the shooter wheel. This lets us mount the wheel on a bolt, instead of having it supported by the motor itself. My guess is the motor bushings won't like having to support a large spinning wheel for a long time.
Unread 20-01-2013, 10:03
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
I would second this. In our shooter design, we've moved the wheel off of the motor itself in order to provide a more stable mount for both. Besides, with the wheel on the motor, isn't is awkward to replace the motor if it fails?
Side note: We actually had started with the wheel on the hub on the motor shaft and mounted the motor to a plate using the front-side mounting holes so thoughtfully provided. It got interesting about 2 hours of testing later when one of those bolts backed out because of the vibrations ... Replacing that bolt required removing the wheel ...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 20-01-2013, 10:10
DonRotolo's Avatar
Back to humble
FRC #0832
Loosen the shaft coupler screws, pull off the wheel plus axle, replace the motor. Not very awkward, but I truly hope we never have to.
