Go to Post See what you don't understand about us students is that we don't know when to stop. - ehfeinberg [more]
Unread 19-01-2013, 15:49
theblazefenix theblazefenix is offline
FRC #4096
theblazefenix is an unknown quantity at this point
New to FRC, and LabVIEW. Need some help.
I was asked to become a programmer for my FRC team (4096). I am currently reading through as many tutorials as possible to familiarize myself with LabVIEW. I have a question as of now.
When I program, do I just work under Team VI's? Also, do i even bother the Robot Main VI?
Thanks for any help.
Cheers
-theblazefenix-
Unread 19-01-2013, 15:53
FRC #4096
Re: New to FRC, and LabVIEW. Need some help.
Also What is an Array? I am currently reading the 2011 manual.
Unread 19-01-2013, 16:18
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
You can access the team code from Robot Main as well.
Unread 19-01-2013, 16:41
Make the changes/additions you want to the code under Team Code and keep any new vi's you may decide to write under there as well.
Leave Robot Main.vi alone.
Unread 19-01-2013, 17:12
FRC #4096
Thanks alot, that makes things a lot clearer.
Unread 19-01-2013, 19:05
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Tutorials for LabVIEW
http://www.youtube.com/playlist?list=PL819E6F5E300A83EF
Unread 19-01-2013, 20:24
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Cheers
-theblazefenix-
How ironic that we are team 4095!
Unread 20-01-2013, 08:22
You asked what an array was.
An array is a collection of similar values stored in a piece of memory. You can access the values one at a time or operate on the collection as a whole.
For example:
If your robot collects ultrasonic data at 20 per second and stores them for five seconds, you now have 100 ultrasonic readings.
Do you put them in individual variables or wires? That would be a lot of variables to keep track of. So, instead, you might want to put the data into one sequential array with values labeled 0 through 99. You could index the array at 0, 20, 40, 60, and 80 to see what was in front of the robot each second as it moved. And you could compute different indices to grab any time's measurement you want.
In other math, you could operate on the whole array at once to convert it to millimeters or inches or offset it to the edge of the robot. You could also break the array into five other arrays and compare or operate on them.
Finally, arrays don't have to be one dimensional. If you have values on a grid, a 2-D array is very useful. This is how images from the camera are typically stored.
Greg McKaskle
