Go to Post There really is nothing else that needs to be said. - billbo911 [more]
Unread 19-01-2013, 19:19
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Holonomic Drive Help
When programming in Labview the rotation does not work on Mecanum-Cartesian when testing on the robot. We wired the throttle to the rotation and when pressed the robot loses connection. Does anyone know how to fix this problem?
Unread 19-01-2013, 19:45
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Re: Holonomic Drive Help
I believe that Rotation is supposed to be hooked up to the X-Axis of the Right Joystick.
Unread 19-01-2013, 19:53
You can hook it up to any axis on any joystick you want to. It just changes the operator interface.
Unread 19-01-2013, 19:54
AKA: Naresh Hing
We are actually using a Logitech Extreme 3D joystick. We used this drive on our 2011 robot on this joystick and it worked perfectly.
Unread 19-01-2013, 21:06
A couple of the potential causes might be:
  • Lack of proper 12v digital sidecar power. Check that the three power lights are all bright and cheerful-5v/6v/12v.
  • Low battery. Watch your battery voltage display on the Driver Station as it happens.
  • Radio 12v power coming from an unregulated 12v connection rather than the special 12v connector reserved for it. Watch the radio power lights to see if they are going through a reboot sequence after it happens.
  • cRIO rebooting due to power brownout. Watch the RSL to see if it stops blinking when the robot fails.
  • Motor controller fault. Watch the motor controller status lights for unusual blink patterns when it happens.
  • Breakers popping. Listen for clicks from the Power Distribution Panel as the robot fails and watch the motor controllers for momentary status light loss.
  • Poor power connections somewhere between the battery and the other critical components. Check power pathways with a multimeter to see how closely it matches the voltage measured at the battery terminals.
  • Check the Driver Station Diagnostics tab for unusual messages or status.
  • Above all, watch and note what every status light and indicator are telling you at the time of the failure.
