Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 19-01-2013, 19:49
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Re: How do I set up the AXIS webcam?
Connect your AXIS Camera to the Computer, using a cross over cable. If you've already tried to configure your AXIS camera, I recommend resetting the AXIS camera by disconnecting power, hold the reset button on the back while you apply power. Release the button when the light around the lens turns amber. Configure your computer ip to 192.168.0.51. Open up the AXIS Setup Tool, select Robot Radio and enter your team name. Your AXIS camera should be configured to 10.40.96.11. Test the connection by opening up the default dashboard, and connect your AXIS camera to the D-Link router.
Feel free to send me a PM if this doesn't work.
Also, I have customized the vision tracking tutorial .vi to work with the dashboard. I recommend doing this as it will take a ton of load off the CPU on the cRIO.
