Go to Post The strength of an alliance is not defined strictly by the sum of its parts. - Jared Russell [more]
Unread 19-01-2013, 15:29
Dillonboy8 Dillonboy8 is offline
AKA: Dillon Knight
FRC #3603 (Reed City Cyber Coyotes)
Dillonboy8 is an unknown quantity at this point
T-Shirt Launcher VI Problem
Hey!
I am programming a T-Shirt Launcher and had to set up a program to launch the T-Shirt out of and air cannon. I used digital output and I am completely SURE that it is the program.Thanks!
My Teleop VI: http://postimage.org/image/5uj6eh0jl/
Unread 19-01-2013, 19:53
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
Re: T-Shirt Launcher VI Problem
I'm sorry but can you explain your errors? I don't think I understand what you're asking, please be a little more specific.
Unread 19-01-2013, 20:13
AKA: Dillon Knight
No errors, the air cannon won't "click" when it's supposed to when I pull the trigger.
Unread 19-01-2013, 21:22
FRC #3039
Well that sounds like a problem! How is your t-shirt cannon made, electrically? What's device takes the digital output and energizes the cannon?
Unread 19-01-2013, 21:38
AKA: Dillon Knight
I am not completely sure at the moment but I think it's an air compressor.
Unread 19-01-2013, 21:58
FRC #3039
Unfortunately I can't find a solution to your problem if I don't know how it works. If it does use an air compressor, you would need to power a relay, that would energize the air compressor.
Unread 19-01-2013, 22:22
AKA: Dillon Knight
We tried that, but the only time it would "click" was when I enabled/disabled teleop in the driver station.
Unread 19-01-2013, 23:24
What is it that is supposed to make the "click"? Is it a relay, a pneumatic solenoid valve, an electromechanical actuator or some sort, or what?
How do you have it wired to the controller? Is it powered by a Spike relay, directly connected to a DIO pin, or what?
If you can show us a schematic, or maybe even just a photo of the connection, we might be able to help make the software talk to the hardware the way you want it to.
My last question is not important to the problem you're having, but I'm curious: Why are you using a Select function to turn a boolean into a numeric 0/1, then using that number as the select input of a Case block, instead of just using the boolean to choose the case directly? Are you expecting to add more cases in the future?
