Go to Post That inspector needs their hard drive wiped and the common sense upgraded from version dingbat 1.0. - Andy Baker [more]
Unread 19-01-2013, 23:48
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Axis Camera Speed Control
We are planning on using the Axis M1011 to do vision processing.
How would we write code in LabView to
1. Take the feed from the camera and line up to robot to shoot.
2. Then adjust the shooter voltage to change speed according to the distance from the goal.
Also it is possible to be able to tell the code to run these adjustments and then stop them to go get more frisbees?
Thanks
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 20-01-2013, 00:34
Re: Axis Camera Speed Control
Use the Rectangular Target - 2013 vision example project. It contains step-by-step directions for adding it to an existing robot project. When you set it up appropriately, it tells you where the center of the target is, right or left of and above or below the center of the video image.
Then you can use the left-right information to decide how much to rotate the robot, and the up-down information to compute how far away the target is.
Unread 20-01-2013, 00:46
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
As I posted in another post, I've been working on a custom vision tracking .vi based on the example code provided. It's designed to work with the dashboard. It's pretty simple, but if you need help, PM me.
