Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Unread 20-01-2013, 01:10
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Urethane Flat Belting that isn't orange
Embrace the orange.
That's easy for you guys...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 20-01-2013, 01:16
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Anybody have a good way to melt this stuff together?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 20-01-2013, 01:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
A hot plate (with a sacrificial sheet of something conductive on top), then quickly into an alignment jig.
For flat belt, you might alternatively throw something together with a heated vertical plate between the two pieces of belt. Push them into the plate to melt the ends, then remove the plate and push them together. (That's how many commercial belt welders work.)
Unread 20-01-2013, 01:42
ejSabathia's Avatar
ejSabathia ejSabathia is offline
AKA: EJ Sabathia
ejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond repute
For those of us who can't embrace the orange....
http://ebelting.com/index.php?main_page=index&cPath=10
Unread 20-01-2013, 09:25
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
The urethane belting in the US is typically made by Eagle Belting (a division of Fenner Drives). The site http://www.fennerdrives.com/eagle/ has all of the Eagle choices on it. Additionally, there are a number of local distributors that sell Eagle belting. Unfortunately, the only non-reinforced flat belting that Eagle makes comes in that lovely dayglo orange.
As for seal the belting, the site listed above also has welding kits. Many of the kits boil down to a simple soldering iron with a flat piece of 1"x1" 18- or 16-gauge steel attached to the tip. The two ends of the belt are heated with the plate (one per side of the plate) and once the urethane gets to a molten temperature, you quickly slip the plate out and mate the ends together. This could be a two-person job or you could get one of the fancy kits that helps you out with some clamps.
Although it doesn't help you much, our team started using Eagle Roundthane this past year and everybody loves it (no welding required). Unfortunately, it doesn't come in a flat form.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 20-01-2013, 16:08
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
A short section of 1 inch aluminum angle makes a perfect alignment tool. You place the two ends of melted belt in the Vee of the angle. If you're using the hot knife method of melting the belt, make a cut most of the way through the angle in it's centre big enough for the knife to fit through. We just use a gas cooktop, or in the field a butane soldering torch flame to melt the belt directly.
Graham.
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 22-01-2013, 14:41
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Here is how we splice our belts.
http://www.youtube.com/watch?v=auJt_...nVjw& index=1
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
