Go to Post Welcome to FIRST! You will soon figure out that there is no "exit strategy" from this program. - David Brinza [more]
Unread 20-01-2013, 01:23
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: paper: Mecanum: we can't even agree on pronunciation?
Originally Posted by lcoreyl View Post
1a) 1 mecanum wheel translates torque to a force 45 degrees from the plane of the wheel
1b) 1 omni wheel translates torque to a force parallel to the plane of the wheel (same as a regular wheel)
Yep, makes sense.
The top half of page 4 makes sense. I get lost on the bold section:
This would imply that a mecanum wheel creates MORE force than the same size regular wheel. You could even put a regular wheel in contact with the mecanum wheel but at a 45 degree angle to increase the amount of torque. Since they are the same diameter wheel you get more torque at the same angular speed which equals more power.
What is the "this" being referenced? Are you proposing that this statement is true or false?
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
