Go to Post What happens on your team is not everyone's business!!!! - Bruneau1727 [more]
Unread 20-01-2013, 12:19
kenfox kenfox is offline
FRC #3322 (Eagle Imperium)
kenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of light
Robot Builder C++ bug
When re-generating C++ code, newly added subsystems and components are not added to Robot.cpp. The bug is caused by a typo in "export/cpp/files.yaml":
--- resources/export/cpp/files.yaml	(revision 619)
+++ resources/export/cpp/files.yaml	(working copy)
@@ -27,7 +27,7 @@
   modifications:
     autonomous: ${exporter-path}CommandBasedRobot-autonomous.cpp
     constructors: ${exporter-path}CommandBasedRobot-constructors.cpp
-    initializanion: ${exporter-path}CommandBasedRobot-initialization.cpp
+    initialization: ${exporter-path}CommandBasedRobot-initialization.cpp
You can work around the problem by manually editing the initialization section of your Robot.cpp and changing "ID=INITIALIZATION" to "ID=INITIALIZANION". Or if you haven't made any changes to Robot.cpp, you can delete it and let Robot Builder generate it from scratch. The bug only happens when updating it.
The tracker at FIRST Forge doesn't seem open for bug reports, so I hope the right people see it here.
Unread 20-01-2013, 12:31
I've been reporting robot builder bugs to the wpilib project, since I couldn't report them in the robot builder project.
Unread 20-01-2013, 20:02
Re: Robot Builder C++ bug
The WPILib project on FIRST Forge seems dead. I can't see any recent commits in the SVN repo. The Robot Builder project seems active, but it doesn't have an open bug tracker.
Unread 20-01-2013, 21:36
While the SVN hasn't been updated for several years, the WPILib project is still active. That is where the file updates are posted. The tracker is also active.l For example, in the Java tracker, there were 5 bugs closed in the last month.
Unread 21-01-2013, 08:59
Thanks, I see that WPILib has categories for all the languages and utilities. I'm now the proud creator of Artifact artf1597.
Unread 21-01-2013, 19:58
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
Thanks for the patch! I've included it in RobotBuilder. You can download it from firstforge, it's r620. The fix will show up in the next update.
Additionally, I've added a tracker for RobotBuilder into the WPILib project and added a link on the home page of the RobotBuilder project. Hopefully, this is much clearer for people trying to report bugs.
