Go to Post Dean will make America gracious again - seth.brugler [more]
Unread 19-01-2013, 20:12
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
Pneumatic Wheel Wobble
im not sure how many teams have encountered this but the pneumatic wheels we ordered form AM are really wobbly. we tried getting the tire as full of air as possible still wobbles. we have a shooter built and the wobble causes a lot of vibration through the whole shooter and im honestly afraid of the wheel exploding and rubber flying around. it seems that the tire part isnt on the hub correctly but no matter what we try it still wobbles so can anyone tell me how to fix this
Unread 19-01-2013, 20:22
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Pneumatic Wheel Wobble
http://www.youtube.com/watch?v=88Ik-99grms Minute 2:08
Andy explains how to fix this issue pretty well.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 19-01-2013, 20:24
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Do realize pretty much any small pneumatic wheel is being for shooting Frisbees is being used way outside of its design parameters. So you need to make everything as good as you can. Make sure the supports for the wheel are beefy (highly technical term. If you can, use bearings on both sides of the wheel. do not depend on the motor bearing to support the wheel. Lunch with Andy (above) also points out the importance of balance at high RPMs.
We have been running our wheels with no air in the tubes just depending on the stiffeness of the side wall & centrifugal force.
Unread 19-01-2013, 20:31
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
We had this same problem with out prototype last week. I would suggest a number of things to check...
1) check whatever you are using to attach the wheel to the motor.
2) do what was already said in the video above
3) balance the weight of whatever is on the wheel to allow you to pump it up with a small piece of aluminum
4) make sure your shaft and bearings are straight (assuming that is your system)
Hopefully this helps, good luck!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 19-01-2013, 21:12
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
We used AM 8” pneumatic wheels last year on drive. 4 out of the 16 we bought had low speed wobble like you mention. We traced issue to the tires not being concentric.
Unread 20-01-2013, 00:32
thedude019's Avatar
AKA: Luke
thank you so much for the help i really never thought of off setting the wheels and quick question does anyone know what the max rpm is for this wheel and is direct drive to a CIM to fast
Unread 20-01-2013, 16:47
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
As pointed out above, these tires often do not seat correctly on the plastic wheel rim first time. Soapy water applied with paint brush in the rim-to-tire gap of a deflated tire will help seat the tire bead correctly when it's re-inflated. Rinse, then let the water dry before spinning up the wheel because you want a firm grip of the bead to the rim seat, and don't get any water inside the tire
If the tire still wobbles, then try a new tire and/or tube. These are low speed wheels, and the production variations on carcass distortion and tread thickness won't be to the same standards as a high speed tire like an auto tire.
Relative to the tire misalignment or distortion, the valve stem won't be contributing much to the out of balance because it's at a much smaller radius, plus the rim is lighter where the valve goes through (because of the hole), and this partially compensates for the weight of the valve and valve stem.
Please be very careful adding balancing weights. If they get loose they will be a high speed projectile. If the tire won't balance itself, I'd say it should not be spun at speed as the out of balance probably indicates some sort of carcass "fault".
Graham.
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
