Go to Post Is this where I get to say "Mama I made it on TV?" - Pauline Tasci [more]
  #31   Spotlight this post!
Unread 09-01-2013, 14:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Mecanum vs Treads
If I might summarize the Mecanum side of things, for easy reference...
Pros: Highly maneuverable, Fast (if you gear it to be), Cheapest Holonomic drive available.
Cons: Less traction, More driver training to use effectively, more expensive than a 6-wheel drive, and prone to wonky driving on uneven surfaces unless you have a suspension, use encoder and gyro closed loop control, and check and maintain the rollers on a regular basis.
So, unless maneuverability is really that incredibly important to you, you probably want to use something other than Mecanums.
On the treads side of things, as far as I'm concerned, a tank tread drivetrain is almost identical to a good 6 wheel drive, only it's more expensive and complicated and less reliable.
  #32   Spotlight this post!
Unread 09-01-2013, 14:51
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
It's even more similar to a treaded 6-wheel robot on level ground...
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
  #33   Spotlight this post!
Unread 09-01-2013, 16:07
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Originally Posted by Peter Matteson View Post
I believe it's 100% of 9 sided robots, it was 3 wheeled.
No 9-wheeled robot has made it.
Also I believe 3 wheeled robots are 2 for 3.
67 -2005 Champion
16 - 2008 Finalist
148 -2008 Champion
- Bryce
Well, I'll argue that every single one of six wheel swerve robots have made it to Einstein. Therefore, you should look into six wheeled swerve. All the advantages of traction with the omnidirectional motion of mecanums.
I have not had experience with Treads (of the tank variety) but one of our current mentors came over from Team 1987, Broncobots, and has informed me many many times that treads are simply not worth their trouble. Without a lot of background and prototyping on them, they are difficult to make, repair, and you're probably going to be traversing the field dead slow. Also, for this year, keep in mind that tank treads will be a heavy system.
I have had experience with mecanum wheels and, while not endorsing them over the other, will share what I know about them. They are somewhat difficult to service between matches, unless you bring a full spare wheel or two to just replace the questionable wheel and fix it at your leisure. While it is true that it is an omnidirectional system, it does require a fairly significant amount of driver practice (as compared to a standard drive) because you have to train yourself to utilize the onmidirectional motion availiable.
I, like those before, do submit that you look into a solid six or eight wheel drive system, as there are many many threads discussing the merits of mecanum vs (6 or 8) wheel drive. It is vastly simpler, lighter than both of the aforementioned drives, and it will be more intuitive for your driver.
Academic Student (Forever)
  #34   Spotlight this post!
Unread 09-01-2013, 16:19
sybert1ger's Avatar
sybert1ger sybert1ger is offline
The Systems Engineer
AKA: JR
FRC #0078 (AIR Strike)
sybert1ger will become famous soon enough
You may want to step back and define what you're trying to accomplish with your drive train. You can't decide which is "better" unless you've defined some metrics you can use for comparison.
As explained in detail by many of these posts, your metrics should include more than just on field performance.
It's really easy to jump right into design comparison but you'll end up with better robot performance if you slow down a few minutes and define what you want your drive train to accomplish independent of implementation.
  #35   Spotlight this post!
Unread 09-01-2013, 16:56
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
If you think that you could pull it off, a teammate and I developed a drop center tread/mechanum drivetrain. If you want to know more and maybe see some image designs, let me know.
  #36   Spotlight this post!
Unread 09-01-2013, 17:31
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Exclamation Re: Mecanum vs Treads
While AM mecanum wheels may not have as much grip as high traction wheels, that doesn't matter too much. You might not be able to push your opponent across the field, but defense with mecanum wheels in a shooting game is as simple as colliding at a medium speed with your opponents.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #37   Spotlight this post!
Unread 09-01-2013, 17:55
pfreivald's Avatar
AKA: Patrick Freivald
The woes of mecanum are not nearly so great as many would like you to believe, but:
1551 has used mecanum for five years (not counting The Game That Shall Not Be Named), and there's a reason last year we switched to octocanum. (Well, several, not counting wanting to challenge ourselves with something new.) Given the experience we've had, I would not choose mecanum-only for this game (and it has nothing to do with wonky driving over the tiny bit of uneven carpet -- that wouldn't stop me for a second!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #38   Spotlight this post!
Unread 09-01-2013, 18:51
CalTran's Avatar
Missouri S&T Senior
So like Octocanum with treads then.
  #39   Spotlight this post!
Unread 09-01-2013, 19:30
Dumper FTW 435's Avatar
Dumper FTW 435 Dumper FTW 435 is offline
AKA: Ryan
FRC #0435 (Robodogs)
Dumper FTW 435 is an unknown quantity at this point
Originally Posted by commodoredl View Post
Mecanums?
Treads?
Why not both?
(Not actually endorsing mecanums, treads, or mecanum-treads)
Please tell me you have more pictures of this or video of it driving. This is the greatest thing ever
  #40   Spotlight this post!
Unread 09-01-2013, 19:55
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Originally Posted by StevenB View Post
I suggest you count the number of Einstein robots which used treads and mecanums.
I don't think that this is ever a good strategy......
341, 67, and 1717 did not make it to Einstein last year, ergo shooting 5+ balls in hybrid, utility arms, and unique end game strategies are a bad choice.
If this is how we think, there would be no new ideas ever.
Out team personally is using mechanums this year because we believe that being able to maneuver around the defense is more effective than withstanding the hits or pushing bots. I don't think that a bump less than .5" tall will be any sort of noticeable problem for the mechanums. I might be wrong, but I wouldn't be too worried about it.
Also, nice job, Eric, on those treads they are sweet. (and dreadfully heavy)
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
  #41   Spotlight this post!
Unread 09-01-2013, 20:24
karomata's Avatar
Rebellious Egyptian
AKA: Mo Elhelw
Not quite, I will be sure to post it though.
  #42   Spotlight this post!
Unread 09-01-2013, 23:30
dtengineering's Avatar
AKA: Jason Brett
This is all very practical advice... and I agree that for winning this years' game, likely neither tank treads nor mecanums are the optimal choice.
Not to understimate the significance of competition, but allow me to point out that your robot will retire from competition just four months from now. Okay... maybe the odd off-season event, but really, once the championship is over, every design choice you made for "winning the game" suddenly becomes redundant.
It is totally okay to use treads or mecanums or swerve or hovercraft technology just beacause you think it is awesome.
We used mecanum wheels in 2007 (it didn't work nearly as well as we'd hoped) but those wheels have kept on being awesome. People still look at the machine and ask about the wheels... allowing me to give a brief lecture on vector mechanics. Our design choice might not have accomplished its mission on the field.... but as far as inspiring science and technology discussions it is still hard at work six years later.
Sure, if you have the time and resources you could build an off-season bot (especially if you are going for the hovercraft drive), or just demonstrate mecanums and treads using VEX... but that isn't quite as cool as having it on a "real" machine.
So kudos for asking advice... you've got plenty of good advice so far in this column... but honestly, if Orville and Wilbur Wright had taken good advice they would have packed up and gone back to their bicycle shop.
Of course, Orville did darn near kill himself flying one of those things. Ignore the advice at your own peril... but feel free to ignore it!
Jason
  #43   Spotlight this post!
Unread 20-01-2013, 05:44
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
I had to revive this thread due to some great discussion found here. Our team has posted a whitepaper addressing a few mecanum misconceptions, and I think all of them are here in this thread: mecanum sacrifices torque and/or speed, is inherently inefficient, et al. The link is in my signature.
*while i'm about to address some points in this thread, i suggest that your responses specific to mecanum go in this thread
Some points more geared to a teams experience with mecanum:
*NOTE: I'm not advocating for mecanum this year (although we are using it... most likely) I've just decided for some reason that now after most teams have decided was a good time to start weeding out bad information.
-We don't do a good job with weight distribution or frame flex and have NEVER even considered a suspension, and our bot operates just fine (i.e. very little deviation from expectation). We even balanced on the bridge last year. (would regular wheels have been easier? sure)
-our inexperienced programmers get gyro/encoder feedback working every year without much trouble and then it reallyoptimizes the driving.
-our drivers have found robot-centric drive vs. regular about the same, and strafing when needed was very easy and intuitive. Field-centric drive is REALLY intuitive and a major upgrade. (I guess you could do a 6wd field-centric program... just never heard of it)
-While we did get 2 sets of andymark 8" (because everyone scared us about them), we never had to do any maintenance during competition (on the wheels that is)
-I've seen over and over the "straw man" argument that if you want to be a block/push defense bot, mecanum is a terrible choice. I've never seen anyone advocate that, and can't recall a team asking input for that idea. Last year driving towards while also orienting the intake towards a ball was actually a defensive technique for which mecanum could be a good choice. The "keep away" defense. Playing "get in the way" style can also have success. Our alliance member last year actually did some heavyweight blocking/pushing (although not as their main strategy) with good success. would 6wd push better? sure. Does mecanum suck at it? no.
-Cool factor IS a valid consideration since we are looking to attract mentors and sponsors
  #44   Spotlight this post!
Unread 20-01-2013, 17:12
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I'm gonna have to disagree with you on one point here. If you use field-oriented driving controls, it probably makes it easier to learn to drive the bot, since it will always move in the direction the joystick is pointed. Combined with a spin control the driver is comfortable with, you've got an intuitively controlled omnidirectional drivetrain, and its driver doesn't need to think about which way it's facing to move somewhere.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
  #45   Spotlight this post!
Unread 20-01-2013, 17:25
Robofreak3130's Avatar
Robofreak3130 Robofreak3130 is offline
FRC #3130 (ERRORs)
Team Role: CAD
Robofreak3130 is an unknown quantity at this point
I would say neither. Both options are way toheavy if you are planning to climb higher than level one.
