Go to Post The folks in Indiana don't play around. - PayneTrain [more]
  #46   Spotlight this post!
Unread 20-01-2013, 17:32
Re: Mecanum vs Treads
Originally Posted by PVCpirate View Post
I'm gonna have to disagree with you on one point here. If you use field-oriented driving controls, it probably makes it easier to learn to drive the bot
Using a gyro you can do field-centric control of any skid-steer vehicle (which includes 6WD). I did this 2 years ago,and it's a hoot. Not sure if experienced 6WD drivers would like it though :-)
  #47   Spotlight this post!
Unread 20-01-2013, 21:31
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Originally Posted by lcoreyl
(I guess you could do a 6wd field-centric program... just never heard of it)
I should have known...
No more putting off doing a mecanum v 6WD off season test now! (for better understanding of both, not crowning the "best", so pls don't start...)
  #48   Spotlight this post!
Unread 21-01-2013, 11:29
buchanan buchanan is offline
FRC #2077 (Laser Robotics)
buchanan is just really nicebuchanan is just really nicebuchanan is just really nicebuchanan is just really nice
I would love to see this done well in competition. It's certainly possible in theory, but it has some challenges apart from those you get doing it with a true holonomic drive.
Team 1988 tried it in the "Overdrive" game with my not-quite-sufficient assistance. The robot was optimized for easy turning, but at the cost of straight line stability. In the end, it was indeed "a hoot" when it worked, but there were issues with control of angular momentum and with gyro limits that made it hard to drive in game situations. You could never quite guess which way the rotation transform thought it was going, and the gyro reset got used nearly as much as the stick.
We learned a lot and it seems like many of the issues could be managed with better mechanical design, so it would be fun to try again with that plus the improved gyros and closed loop motor controls we have now. We haven't gotten around to it because our drivetrain focus has been on learning to do holonomic right.
Field-relative control software for non holonomic drive trains must make decisions in the software that aren't issues with omni/mecanum drive trains. In particular, the tradeoff between changing heading and changing position. Holonomic drives have the same issue, but they're entirely taken care of by physics - the software doesn't have to specify the tradeoffs. I'm guessing a properly tuned program could approach equivalent performance if the software were carefully matched to the hardware, but it's not trivial to do, and it's on top of software that's more complex to begin with.
Either is correct, it's absolutely possible. But unless/until it's successfully done in real life the ability to implement field-relative controls must number among the advantages of holonomic drivetrains over others.
  #49   Spotlight this post!
Unread 21-01-2013, 13:33
foote stepped in
AKA: E. Foote
FRC #0868
IIRC the kit gyro in 2008 had a limit of about 80 degrees / second, which is wholly inadequate for anything teams do.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
