Go to Post Drive fast...drive true...otherwise it will kind of crush you - techhelpbb [more]
Unread 19-01-2013, 00:51
programmerB programmerB is offline
FRC #0968
programmerB is an unknown quantity at this point
Arrow PWM arrangement
For the simple template code what is the pwm numbering in the code. Like as in in the code what numbers are they assigned.
Unread 19-01-2013, 00:59
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: PWM arrangement
What?
On your robot, the PWM assignment is going to depend on which port you plug the motor controllers into on the sidecar, if that's what you mean.
The templates shouldn't have anything pre-coded, just the basic boilerplate code.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 20-01-2013, 20:51
FRC #0968
Re: PWM arrangement
so does that mean in the "simple template" code has no presets for pwms
