Go to Post Mike Wade was the Fall offseason guy. - Michael Leicht [more]
Unread 19-01-2013, 20:00
lemonzap lemonzap is offline
Head Programmer
FRC #2928 (Viking Robotics)
lemonzap is on a distinguished road
motor controller profiles
My programmer team and I just collected some data on the operation of all 3 motor controllers. Jaguars, Victors, and Talons. We put a motor on a wheel with a gearbox and an encoder. We collected the minimum value that had to be sent to the controller to start the motor moving forward and reverse, the maximum forward and reverse speeds, and a graph of speed over time. We had the program increase the value sent to the controller by 0.01 every 0.5 seconds until it reached full power then decrease the value by 0.01 until it reached full reverse power, then increases again until it reached a stop. I've made sure the controllers were properly calibrated and used the correct class for each.
Jaguar:
Start value: 0.110
Reverse start value: -0.060
Top speed: 543.478 units/sec
Reverse top speed: -543.478 units/sec
Victor 884:
Start value: 0.090
Reverse start value: -.060
Top speed: 657.895 units/sec
Reverse top speed: -568.182 units/sec
Talon:
Start value: 0.070
Unread 19-01-2013, 20:04
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: motor controller profiles
Were you using the correct class for each controller? Each motor controller has different input timing requirements.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 19-01-2013, 20:08
1) Was each motor controller properly calibrated?
2) Did you use the proper driver for each motor controller?
3) You didn't mention which model Victor you tested. It looks like the older 884, not the new 888.
Unread 19-01-2013, 22:22
Head Programmer
Ah. ya I noticed that there were different classes for the different controllers but forgot to swap out the code at the time. The talon was properly calibrated and I'm fairly sure the Victor was. Ill correct the data when I re-run the tests tomorrow.
Unread 19-01-2013, 22:43
Since you're not using a joystick, can you please describe your calibration procedure ?
(I know how I'd do it with a test like this, but for completeness it would be helpful if you'd document how you did it)
Unread 19-01-2013, 23:16
Head Programmer
The reason I believe the Victor may have been improperly calibrated is because the lights didn't light up exactly how the instructions said they should. I think that on the Victor we may have just done a factory reset. I will confirm that everything has been properly calibrated before the test tomorrow so we can get more accurate data.
Unread 19-01-2013, 23:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Here's the data that's present overlaid on top of each other (as best I can) for comparison:
Unread 20-01-2013, 22:01
Head Programmer
I re-ran the tests with the motor controllers properly calibrated and using the correct classes. the graphs have been updated but there was no significant change. I hope this data will be useful. also keep in mind that the values will change depending on the motor, gearbox, encoder, and battery life. These values are fairly arbitrary on their own and are mainly useful for seeing the comparison between the different types of motor controllers. For instance the dead zone around zero for talons seems to be significantly smaller than the the dead zone for the other 2.
Unread 20-01-2013, 22:20
Is this a typo? It doesn't agree with the graph.
Unread 22-01-2013, 01:51
Head Programmer
I believe it was a fluke in the data. A random sudden spike.
Unread 22-01-2013, 10:03
If you have a Victor 888 and would be willing to run your test with that, it would make your data set complete and help put things in perspective.
Unread 23-01-2013, 01:49
Head Programmer
I definitely would but I sadly don't have any, and I don't think that we'll be getting any because the talons seem pretty reliable. I do wish we did though so I'll probably have someone order them after this season.
Unread 23-01-2013, 02:56
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
If you haven't used your IFI PDV yet, you can get two 888s or two Jags with it.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 23-01-2013, 13:01
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Lemonzap,
Thanks for posting, this data looks very interesting.
Would you consider sharing the code that you used for the comparison? If you did, perhaps someone else could repeat the test with the 888.
Al G.
Alan Gilgenbach
C.O.R.E 2062
