Re: Programming Logitech Joystick--how to access right thumbstick?
You can find the axes (if you're using Windows) by going into Control Panel, Devices and Printers, and right-click on the Joystick. Then, go into properties and you should see the info there. If you can't see some data, begin a calibration and look at the data there, just cancel before it saves the calibration profile.
If there are only 3 axes, you can just use stick.GetZ too, unless you have more than that. In that case, follow kittylan's instruction.
Hope this helps!
